- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Enabling or disabling Chinese, Japanese, Korean OCR
Automation Suite on Linux Installation Guide
Last updated Feb 20, 2025
If you want to use the OCR for Chinese, Japanese, Korean endpoint in an offline environment, you need to install the offline bundle and once the bundle is installed, you have to enable the OCR. For more information on how to install offline bundles, check the ML packages offline installation page from the Document Understanding User Guide.
Note:
- When OCR for Chinese, Japanese, Korean is used in Document Understanding, make sure that you configured the activity with the public endpoint of the OCR, and the Document Understanding API Key.
- OCR for Chinese, Japanese, Korean is only supported in Document Understanding deployed in Automation Suite. This is not supported in Document Understanding deployed in AI Center connected to an external Orchestrator.
There are two ways in which you can enable the Chinese, Japanese, Korean OCR:
- Using ArgoCD.
- Using the
cluster_config.json
file.Note: You can only enable the Chinese, Japanese, Korean OCR usingcluster_config.json
starting with Automation Suite version 2023.4.11.
- Open ArgoCD.
- Open the Document Understanding framework.
- Select the Parameters tab.
Navigate to
du-cjk-ocr.enabled
Select Edit and set the value to
TRUE
. - Select Save.
Note: The endpoint for OCR for Chinese, Japanese, Korean in
an Automation Suite installation is constructed as
{Cluster_FQDN}/du_/cjk-ocr/
