- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
This is one of two ways in which you can migrate your standalone Orchestrator to Automation Suite.
For more information, see Migration options.
The tool can migrate to either Automation Cloud or Automation Suite, but this page describes the process of migrating to Automation Suite. For instructions on migrating to Automation Cloud, see the Automation Cloud documentation instead.
You can use the UiPath Automation Cloud™ Migration Tool to automatically migrate entities from your standalone Orchestrator to the Orchestrator service in Automation Suite.
You can only use the Automation Cloud Migration Tool if:
- your standalone Orchestrator version is 2019.10.x, 2020.10.x, 2021.4.x,, 2021.10.x, or later.
- your Automation Suite version is 2021.10.x or later.
When you run the Automation Cloud Migration Tool, it automatically creates the following entities in Automation Suite to match your standalone Orchestrator setup:
Entity |
Migrated |
Not Migrated |
Settings |
Yes, with exceptions (see on the right). |
Some settings that are exposed to the tenant on the read path cannot be modified in Automation Suite, like host logo and color. Passwords in the Settings table cannot be exported because the API removes the values from the response. As a result no passwords will be migrated. This affects email alerts (SMTP password) and external feeds with basic authentication. |
Packages |
Migrates all packages and all package versions. If a package feed is external and configured with basic authentication, the credentials will need to be input after the migration completes. |
If a package feed is external and not accessible over the internet, entities that rely on these packages are not migrated. |
Libraries |
Tenant-level feeds only. |
If a library feed is at the host level or is external and not accessible over the internet, entities that rely on these libraries are not migrated. |
Calendars |
Yes |
N/A |
Machines |
Yes, but if there are not enough licenses to accommodate Machine slot assignments, the Machine will be imported with all slots set to 0. |
Machine keys are not migrated. |
Folders |
Yes |
Personal workspace folders are not migrated. |
Environments |
Yes, for classic folders. |
N/A for modern folders. |
Robots (classic) |
Yes, but if there are not enough licenses to accommodate robot creation, the robot is skipped during import. |
Skipped when licenses run out and an error is logged for each. |
Robots (modern) |
Modern robots are migrated if the user with which they are associated exists in Automation Suite and has the same email address. |
Environment associations |
The robot-environment mapping is migrated. |
N/A |
Processes |
Processes are migrated. The tool may refer to these as Releases. |
N/A |
Queues |
Yes |
N/A |
Triggers |
Triggers are migrated, but are all set as disabled. | |
Assets |
Per-user asset values in modern folders are not supported. The asset is imported with the default value or skipped if none is set. |
Machine associations |
Robot-machine mappings are migrated. |
N/A |
Entities not migrated
The following entities are not migrated by the tool:
- Folder feeds
- Users
- Queue items
- Action catalogs
- Webhooks
- Testing entities (test sets, test cases, test executions, test schedules, test data queues)
- Logs
Before opening the tool, make the following preparations:
- Make sure you have sufficient robot licenses in Automation Suite to match the number of robots being migrated (Admin > Licenses > Robots & Services). The tool only migrates robots as long as there are licenses available, after which it starts to skip robots.
- You must have administrator credentials for the standalone Orchestrator and View permissions for all entities being migrated. If you don't have the View permission for some entities, those entities are not migrated.
- You must be an organization administrator in Automation Suite.
- To run the tool, you need a machine that:
- can connect to the standalone Orchestrator and to Automation Suite (has internet access)
- has the Windows operating system
- has .NET Core Desktop Runtime for x64 installed.
- Download the tool on the mentioned machine from this link.
- Register the tool as an external application in the target Automation Suite organization.
Registering the tool as an external application
The migration tool needs to connect to the Orchestrator service API in Automation Suite to create the migrated entities. It uses the OAuth flow for this and therefore must be registered in Automation Suite as an external application.
The tool can migrate one tenant at a time. You can run the tool multiple times for each of your tenants.
With each run, the tool:
Connects to your standalone Orchestrator to export entities for the given tenant.
Connects to Automation Suite to import and create the migrated entities in the Orchestrator tenant.
For more information about entities that are subject to migration, see Entities Being Migrated.
To run the tool:
Because the tool cannot migrate everything, there are some final tasks that you must perform manually to obtain the same setup as you had in your standalone Orchestrator.
If you need assistance with an issue encountered during export, import, or after import, open a Support ticket and include the following files:
- Log file (in the logs sub-folder)
- Export report file (in the MigrationAssets sub-folder)
- Import report file (in the MigrationAssets sub-folder)
In addition to these files, it would be helpful to know:
- The version of your standalone Orchestrator
- Your Automation Suite organization and tenant names.
