- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
OUT OF SUPPORT
Last updated Feb 25, 2025
AKS upgrades cause Automation Suite to fail
linkDescription
linkAn upgrade known issue affecting AKS causes Automation Suite 2023.4.1-2023.4.5 to fail. When trying to upgrade AKS, the
argocd-redis-ha-server
pod is put in error state.
Solution
linkTo fix the issue, take the following steps:
Uninstall the existing ArgoCD chart by running the following command. Note that the
kubeconfig
path should be set to the cluster path.helm uninstall argocd -n argocd
helm uninstall argocd -n argocd -
Search for the
profile
key in the root level ofinput.json
If it is present, change the value of the
profile
key todefault
If not present, add the
"profile":"default"
Reinstall the ArgoCD chart by running the following command:
uipathctl manifest apply input.json --versions versions.json --only argocd
