- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
OUT OF SUPPORT
Last updated Feb 25, 2025
When migrating standalone Orchestrator to Automation Suite, a series of additional steps might be required, depending on the way you configured standalone Orchestrator.
Before starting the migration operation, you may need to prepare your settings. For details, see Preparing Orchestrator.
After completing the migration operation, you may need to adjust some of your settings. For details, see Updating the Orchestrator configuration.
