- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Health check of Automation Suite Robots fails
OUT OF SUPPORT
Last updated Feb 25, 2025
Following an Automation Suite on AKS installation or upgrade, the backup setup does not work because of a failure to connect to Azure Government.
You can fix the issue by taking the following steps:
- Create a file named
velerosecrets.txt, with the following contents:AZURE_CLIENT_SECRET=<secretforserviceprincipal> AZURE_CLIENT_ID=<clientidforserviceprincipal> AZURE_TENANT_ID=<tenantidforserviceprincipal> AZURE_SUBSCRIPTION_ID=<subscriptionidforserviceprincipal> AZURE_CLOUD_NAME=AzureUSGovernmentCloud AZURE_RESOURCE_GROUP=<infraresourcegroupoftheakscluster>AZURE_CLIENT_SECRET=<secretforserviceprincipal> AZURE_CLIENT_ID=<clientidforserviceprincipal> AZURE_TENANT_ID=<tenantidforserviceprincipal> AZURE_SUBSCRIPTION_ID=<subscriptionidforserviceprincipal> AZURE_CLOUD_NAME=AzureUSGovernmentCloud AZURE_RESOURCE_GROUP=<infraresourcegroupoftheakscluster> - Encode the data in the
velerosecrets.txtfile as Base64:export b64velerodata=$(cat velerosecrets.txt | base64)export b64velerodata=$(cat velerosecrets.txt | base64) - Update the
velero-azuresecret in theveleronamespace, as shown in the following example:apiVersion: v1 kind: Secret metadata: name: velero-azure namespace: velero data: cloud: <insert the $b64velerodata value here>apiVersion: v1 kind: Secret metadata: name: velero-azure namespace: velero data: cloud: <insert the $b64velerodata value here> - Restart the
velerodeployment:kubectl rollout restart deploy -n velerokubectl rollout restart deploy -n velero
