- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Migrating standalone Test Manager
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
openssl commands to validate a chain of certificates (CA, intermediate, and server), and separate or combine certificates.
You can bring certificates as follows:
Scenario 1: Three crt/pem files including CA, intermediate, and server certs and a private key.
Scenario 2: Two crt/pem files including CA and server certs and a private key.
Scenario 3: One pfx file containing all CA/intermediate and server certs and a private key.
The following table describes the used file names:
File name |
Description |
A CA certificate. |
An intermediate certificate. |
A certificate containing CA and intermediate certificates. |
A server certificate. |
A private key used to generate the
server.crt.
A pfx certificate file containing CA, intermediate, server certificates, and the server private key. |
When you bring three different cert files (CA, intermediate, and server), take the following steps for validation:
Combine the CA with the intermediate certs (applicable only for Scenario 1).
cp ca.crt ca-bundle.crt cat intermediate.crt >> ca-bundle.crtcp ca.crt ca-bundle.crt cat intermediate.crt >> ca-bundle.crt -
Check the server cert contains (specifically the
subject alternative namesandvalidityfields.openssl x509 -in server.crt -text -nooutopenssl x509 -in server.crt -text -noout -
Check if the server cert was signed by the CA server.
openssl verify -CAfile ca-bundle.crt server.crtopenssl verify -CAfile ca-bundle.crt server.crtOutput:
server.crt: OKserver.crt: OK -
Check if the server cert was generated by the server private key by comparing the md5 hashes. If the following commands' outputs match, then it validates that the server cert was generated using the private key.
openssl x509 -noout -modulus -in server.crt | openssl md5openssl x509 -noout -modulus -in server.crt | openssl md5Server cert output:
(stdin)= c9b0c5c3fe11b0b09947415236c4a441(stdin)= c9b0c5c3fe11b0b09947415236c4a441openssl rsa -noout -modulus -in server.key | openssl md5openssl rsa -noout -modulus -in server.key | openssl md5Server private key output:
Generate the pfx file from the server cert and the private key. Once the following command is run, you are prompted to type a passcode twice. Thepasscode is always required to decrypt the pfx file.
openssl pkcs12 -inkey server.key -in server.crt -export -out server.pfxopenssl pkcs12 -inkey server.key -in server.crt -export -out server.pfxOutput:
Enter Export Password: Verifying - Enter Export Password:Enter Export Password: Verifying - Enter Export Password:
When you bring one certificate in pfx format containing CA, intermediate, server, and private key, you can use the pfx file as an identity token signing certificate, but you must break the pfx file into multiple cert files. The following steps describe how to break the pfx file accordingly.
Export the CA certificate (including intermediate if provided in the pfx file):
openssl pkcs12 -in server.pfx -cacerts -nokeys -chain | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > ca.crtopenssl pkcs12 -in server.pfx -cacerts -nokeys -chain | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > ca.crt -
Export the server certificate:
openssl pkcs12 -in server.pfx -clcerts -nokeys | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > server.crtopenssl pkcs12 -in server.pfx -clcerts -nokeys | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > server.crt -
Export the private key:
openssl pkcs12 -in server.pfx -nocerts -nodes | sed -ne '/-BEGIN PRIVATE KEY-/,/-END PRIVATE KEY-/p' > server.keyopenssl pkcs12 -in server.pfx -nocerts -nodes | sed -ne '/-BEGIN PRIVATE KEY-/,/-END PRIVATE KEY-/p' > server.key
