Last updated Dec 4, 2025
AWS Marketplace deployment parameters
This page documents the AWS parameters you need to configure when deploying Automation Suite to AWS.
Table 1. Network choice
Parameter label (name)
Default value
Deploy to an existing VPC
Choose true to deploy Automation Suite in an existing VPC.
Table 2. Network configuration
Note: Configure this section only when deploying Automation Suite in an existing VPC.
Default value
VPC CIDR
10.0.0.0/16
VPC CIDR block. Example: x.y.0.0/16, x.y.z.0/24.
VPC ID
Requires Input
ID of the existing VPC.
Public subnet IDs
Blank string
List of public subnet IDs to deploy the internet-facing Load Balancer and the Bastion host.
Private Subnet IDs
Requires Input
List of private subnet IDs.
Table 3. Availability Zone configuration
Note: Configure this section only when deploying Automation Suite in a new VPC.
Default value
Availability Zones
Requires input
Choose up to three Availability Zones to use for the VPC subnets.
Table 4. Common networking configuration
Default value
Number of Availability Zones
2
Choose the number of Availability Zones to use in the VPC. This must match the number of zones selected in the Availability Zones parameter.
Deploy Bastion host
Deploy a Bastion host inside the public subnet.
CIDR for bastion's ingress for SSH traffic
Empty string
Ingress Security Group CIDR (for SSH). Configure this parameter only if you have set the Deploy Bastion host parameter to true. Set to x.x.x.x/32 to allow one specific IP address access, 0.0.0.0/0 to allow all IP addresses access, or another CIDR range.
Table 5. Automation Suite node configuration
Default value
Server instance type
c5.4xlarge
Choose the node type for the Server node instances.
Server instance count
3
Choose the number of nodes to be deployed as Server node instances.
Agent instance type
c5.4xlarge
Choose the node type for the Agent node instances.
Agent instance count
1
Choose the number of nodes to be deployed as Agent node instances.
GPU agent instance type
p3.2xlarge
Choose the node type for the GPU Agent node instance.
Task Mining agent instance type
c4.8xlarge
Choose the node type for the Task Mining Agent node instance.
AS Robots agent instance type
c5a.4xlarge
Choose the node type for the AS Robots Agent node instance.
AS Robots agent instance count
1
Choose the number of nodes to be deployed as AS Robots Agent node instances.
Table 6. Automation Suite instance configuration
Default value
Instance key pair
Requires input
Existing key pair to connect to virtual machine (VM) instances.
IAM role ARN
Blank string
ARN of a pre-deployed IAM Role with sufficient permissions for the deployment. Leave empty to create a new role automatically during deployment.
IAM role name
Blank string
Name of a pre-deployed IAM role with sufficient permissions for the deployment. Leave empty to create a new role automatically during deployment.
Table 7. Automation Suite deployment configuration
Default value
Enable cluster backup
Enable the cluster backup.
Use a shared bucket for external storage
Enable a shared bucket across products. If enabled, Process Mining and Data Service still require a dedicated bucket each.
Load balancer
ALB
Select either an Application Load Balancer (ALB) or a Network Load Balancer (NLB). If you select a Network Load Balancer, then you need to manually configure the TLS certificates post deployment.
Ingress Security Group CIDR (for https)
Empty stringIngress Security Group CIDR (for HTTPS). Set the CIDR to allow access to Automation Suite. Set the CIDR to x.x.x.x/32 to allow one specific IP address access, 0.0.0.0/0 to allow all IP addresses access, or another CIDR range.
Perform installation
Perform the Automation Suite installation. Choose false to perform only infrastructure provisioning and configuration.
Automation Suite version
e.g. 2023.10.1
Automation Suite version to install
Add GPU-enabled VMs
Choose true to add a GPU-enabled VM to the deployment.
Extra configuration keys
Blank string
Extra configuration keys to add to the cluster configuration. Leave empty to use the default configuration.
Validity of the self-signed certificate
1825
Validity (in days) of the self-signed certificate that the deployment uses to encrypt traffic inside the VPC.
Disable presigned URL
Enable or disable objectstore access via pre-signed URLs.
Table 8: Automation Suite external registry configuration
Default value
External registry Fully Qualified Domain Name
Requires input
FQDN for the external registry. Leave empty to not use an external registry.
External registry user name
Requires input
User name for connecting to the external registry. Leave empty to not use an external registry.
External registry password
Requires input
Password for connecting to the external registry. Leave empty to not use an external registry.
Table 9. Automation Suite service configuration
Default value
Service install flags
(multiple)
Choose if a specific service is installed in the cluster.
Table 10. Automation Suite external Orchestrator configuration
Default value
Connect AI Center to an external Orchestrator
Register AI Center to an external Orchestrator.
Orchestrator URL
Blank string
URL of the external Orchestrator to which AI Center connects.
Example: https://my-orchestrator.net
Identity URL
Blank string
URL of the Identity server used to authorize AI Center.
Example: https://my-orchestrator.net/identity
Base64 encoded Orchestrator certificate
Blank string
Base64 encoded Orchestrator certificate string
Example: UExBQ0VIT0xERVI=
Base64 encoded Identity certificate
Blank string
Base64 encoded Identity certificate string
Table 11. DNS or SSL configuration
Default value
Hosting FQDN
Requires input
Fully qualified domain name (FQDN) for Automation Suite. This must be either a subdomain or root domain of the ID of Amazon Route 53-hosted zone parameter.
Blank string
Enter the ID of the Amazon Route 53-hosted zone or leave blank. For details, see Valid domain name.
ARN of the ACM-hosted certificate
Blank string
ARN of the certificate present in the Amazon Certificate Manager (ACM) to use with the ALB. Leave empty to create the public certificate during deployment.
Use internal load balancer
Choose if you want to use an internal load balancer.
Table 12. Amazon RDS configuration
Default value
Engine of SQL Server deployed on Amazon RDS
sqlserver-se
Choose the Amazon Relational Database Service (Amazon RDS) SQL engine
Version of SQL Server deployed on Amazon RDS
15.00
Choose the Amazon RDS SQL version.
AWS KMS Key Id used to encrypt Amazon RDS storage
Blank string
KMS Key ID to use for the encryption of the Amazon RDS storage. Leave empty to skip encrypting the Amazon RDS storage.
