- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Kerberos authentication configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Configuring Dapr with Redis in cluster mode
- Exploring Logs
- Exploring summarized telemetry
This page provides instructions on the operations you can perform after deploying Automation Suite to AWS.
- Under CloudFormation > Stacks, you can find all of your deployments.
- Select the stack you deployed, a status of CREATE_COMPLETE indicates the deployment has completed successfully.
The installation process generates self-signed certificates on your behalf. By default, these certificates are compliant with FIPS 140-2 and expire after 1825 days, but you can choose any of the following expiry periods at the time of deployment: 90, 365, 730, 1825, or 3650 days.
You must replace the self-signed certificates with certificates signed by a trusted Certificate Authority (CA) as soon as the installation completes. If you do not update the certificates, the installation will stop working after the certificate expiry date.
If you installed Automation Suite on a FIPS 140-2-enabled host and want to update the certificates, make sure they are compatible with FIPS 140-2.
For instructions, see Managing certificates.
After completing an Automation Suite installation using the AWS deployment template, you can enable FIPS 140-2 on your machines. For instructions, see Security and compliance.
/root/installer directory.
The Cluster Administration portal is a centralized location where you can find all the resources required to complete an Automation Suite installation and perform common post-installation operations. For details, see Getting started with the Cluster Administration portal.
To access the Cluster Administration portal, take the following step:
https://${CONFIG_CLUSTER_FQDN}/uipath-management.The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all Automation Suite areas: administration pages, platform-level pages, service-specific pages, and user-specific pages.
To access Automation Suite, take the following steps:
- Go to the following URL:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Default organization.
- The username is orgadmin.
- Retrieve the password by selecting the secrets link provided in the output table for AutomationSuiteSecret. Go to Retrieve Secret Value for the credentials.
The host portal is where system administrators configure the Automation Suite instance. The settings configured from this portal are inherited by all your organizations, and some can be overwritten at the organization level.
To access host administration, take the following steps:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Host organization.
- The username is admin.
- Retrieve the password by selecting the secrets link provided in the output table for HostAdministrationSecret. Go to Retrieve Secret Value for the credentials.
You can use the ArgoCD console to manage installed products.
To access ArgoCD, take the following steps:
https://alm.${CONFIG_CLUSTER_FQDN}. - The username is admin if you want to use the ArgoCD admin account, or argocdro if you want to use the ArgoCD read-only account.
- Retrieve the password by selecting to the secrets link provided in the output table for ArgoCdSecret. Go to Retrieve Secret Value for the credentials.
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
- Username: admin
- Password: to retrieve the password , run the following command:
kubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -dkubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -d
To update the default password used for Dex authentication while accessing the monitoring tools, take the following steps.
Run the following command by replacing
newpasswordwith your new password:password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]" -
Run the following command to update the password:
./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -f --accept-license-agreement./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -f --accept-license-agreement
The templates provide automations for cluster operations leveraging Systems Manager documents.
Using Systems Manager documents
To use the Systems Manager documents, take the following steps:
UpdateAMIDocument
The SSM document creates a new Launch Template version for the server and agent Automatic Scaling Groups with an updated AMI ID.
Usage
The document exposes 2 parameters:
ImageName(e.g.:RHEL-8.6*_HVM-20*) – If theImageNameparameter is provided and AMI that matches theImageNamewill be set on the Automatic Scaling Groups;AmiId(e.g.:ami-032e5b6af8a711f30) – If provided, theAmiIdtakes precedence overImageNameand is set on the Automatic Scaling Groups.
ImageName stored in Parameter Store is used as default value.
RegisterAiCenter
The SSM document registers AI Center to the external Orchestrator provided at deployment time.
Usage
IdentityToken, which is an installation access token generated by the external Identity service. Since the token has a short availability
(approximately 1-2 hours), we recommend generating it just before running the SSM document. For instructions, see Installation key.
OnDemandBackup
Creates a snapshot of the Automation Suite cluster. Does not perform a backup on the SQL server.
Usage
This SSM document does not require any parameters.
Execution logs
captureOnDemandBackup step.
GetAllBackups
Lists all snapshot available in the Automation Suite cluster.
Usage
Execution logs
getSnapshotList step.
OnDemandRestore
Restores the Automation Suite cluster to a snapshot.
Usage
SnapshotName parameter. To get a snapshot, use the GetAllBackups document and check the logs.
Execution logs
To view the execution logs, take the following steps:
- Validating the installation
- Updating certificates
- Enabling FIPS 140-2
- Accessing the installer package
- Accessing the deployment outputs
- Accessing the Cluster Administration portal
- Accessing the Automation Suite portal
- Accessing host administration
- Accessing ArgoCD
- Accessing the monitoring tools
- Accessing cluster VMs
- Performing cluster operations
- Using Systems Manager documents
- UpdateAMIDocument
- RegisterAiCenter
- OnDemandBackup
- GetAllBackups
- OnDemandRestore
