Last updated Dec 4, 2025
Step 8: Configuring the disks
Before performing an Automation Suite installation, you must partition and configure the disk using LVM, so that you can alter its size easily and without any data migration or data loss.
Partitioning the disks
The default partitioning structure on RHEL machines is not suitable for installing Kubernetes. This is because the Kubernetes infrastructure is usually installed under the /var partition, which is allocated only 8 GB of space by default.
Note:
  • The supported format for the disks is ext4 or xfs.
  • You must create all partitions using LVM to ensure that the cluster data can reside on a different disk but still be viewed coherently. This also helps extend the partition size in the future without the risk of data migration or loss.
  • All the pods and application logs are stored under the /var/log/pods directory. Make sure that the capacity of this directory is at least 8 GB. We also recommend configuring logrotate to rotate the logs at an interval ranging from daily to weekly.
The disk requirements for online and offline installations are the same, except for the extra space needed to unpack the offline UiPath® bundle.
For the RHEL OS, make sure you have the following minimum mount point sizes on the machine.
Disk label
Server
Agent
Partition
Size
Purpose
Cluster disk
available
available
/var/lib/rancher
190 GB
Stores the container images and layers.
/var/lib/kubelet
56 GB
Stores runtime Kubernetes configurations such as secrets, configmaps, and emptyDir.
/opt/UiPathAutomationSuite
10 GB
Stores the installer binary.
etcd disk
available
not available
/var/lib/rancher/rke2/server/db
16 GB
Stores the distributed database for Kubernetes
Block storage
available
not available
/datadisk/insights
15 GB
Required for Insights.
/datadisk/monitoring
50 GB
Required for the monitoring tools.
/datadisk/registry1
200 GB
Required for the Docker registry.
/datadisk/objectstore2
10 GB
Required for ceph-mon.
Objectstore2
available
not available
N/A
512 GB
Required for in-cluster objectstore.
AI Center3
available
available
N/A
51 GB minimum and 105 GB recommended for 1 training pipeline.
Required only if you install AI Center.
UiPath® bundle disk
available
not available
/uipath512 GB
Required only for offline installations to store the offline bundle
1 This refers to the in-cluster Docker registry and is not applicable if you use an external registry.
2 This refers to the in-cluster objectstore and is not applicable if you use an external objectstore.
3 This refers to the storage required by the AI Center training pipeline. The disk is required only on the machines on which you plan to run the AI Center training pipeline and on the dedicated Task Mining node. We recommend attaching this disk on the agent machines.
Note:
We recommend that you do not use OS disk for any of the above purposes, to ensure processes get their fair share of resources.
Using the script to configure the disks
Downloading the script
You can use the configureUiPathDisks.sh script to configure and partition the disks.
For download instructions, see configureUiPathDisks.sh.
Running the script
You can use the configureUiPathDisks.sh script for the following purposes:
  • Configure the disks and mount points for a new Automation Suite cluster installation;
  • Resize the data disk post-installation.
To make the script executable, run the following command:
chmod +x ./configureUiPathDisks.shchmod +x ./configureUiPathDisks.sh
To provide the required permissions to the script, run the following command:
chmod +x configureUiPathDisks.shchmod +x configureUiPathDisks.sh
For more details on the script usage, run the following command:
sudo ./configureUiPathDisks.sh --helpsudo ./configureUiPathDisks.sh --help
Configuring the cluster disk on all the machines
To configure the cluster disk, run the following command on all the machines:
./configureUiPathDisks.sh --cluster-disk-name name_of_cluster_disk ./configureUiPathDisks.sh --cluster-disk-name name_of_cluster_disk
Configuring the etcd disk on all the server machines
To configure the etcd disk, run the following command on all the server machines:
./configureUiPathDisks.sh --etcd-disk-name name_of_etcd_disk ./configureUiPathDisks.sh --etcd-disk-name name_of_etcd_disk
Important:
The etcd disk configuration must be performed only after completing the cluster disk configuration.
The order of configuration must be preserved, because the etcd disk is mounted inside the cluster disk.
If this step is executed before configuring the cluster disk, it can lead to data loss after a machine reboot, since the kernel automatically mounts disks in sequence, first the cluster disk and then the etcd disk.
Configuring the data disk on all the server machines
To configure the data disk, you must identify the specific disk to be used. Run the lsblk command to list all the block devices, their sizes, and mount points. Use the disk size to identify the relevant disk (for the --volume flag, the 512 GB data disk should be used).
Run the following command on all the server machines and provide the necessary flags based on your requirements:
./configureUiPathDisks.sh --volume name_of_data_disk./configureUiPathDisks.sh --volume name_of_data_disk
Flag
Value
-v|--volume
Disk name example: /dev/sde
You need the disk name when partitioning the disks that host the various mounts for monitoring, Insights, objectstore, and registry.
Providing the disk name is mandatory in the first-time configuration of the disk. If it is not provided during the subsequent run, then any existing disk associated with uipathdatavg is used to create the partition for the selected component.
--docker-registry
Optional. Only required if the external registry is not available.
--monitoring
Optional. If the flag is not passed during the first run execution, it automatically creates the partition for monitoring (Prometheus storage). However, the flag is required in the subsequent run, during the resize of the monitoring partition along with the --resize flag.
--objectstore
Optional. Only required if the external objectstore is not available.
--insights
Optional. If the flag is not passed during the first run execution, it automatically creates the partition for Insights. However, it is required in the subsequent run, during the resize of the Insights partition along with the --resize flag.
--resize <int>
Optional. If the integer value is provided, the selected component is resized, provided that enough space is available. Otherwise, the entire disk is consumed to expand the selected partition. It is mandatory to indicate precisely one partition that must be resized.
--robot-package-cache
Path to the location on the Automation Suite Robots node to download the package for caching. This must be performed only on the Automation Suite Robots node.
You can also use the command to resize the selected partition with the help of the --resize flag, as shown in the following example:
./configureUiPathDisks.sh --volume /dev/sde --docker-registry --resize 300./configureUiPathDisks.sh --volume /dev/sde --docker-registry --resize 300
The example shows how to attach the /dev/sde disk to the existing data disk and how to resize the docker registry partition to 300 GB.
Configuring the objectstore disk on all the server machines
This step is only required if the external objectstore is not available.
You can add or expand your storage size for the in-cluster objectstore by running the following script on all server nodes:
./configureUiPathDisks.sh --ceph-raw-disk-name name_ceph_raw_disk./configureUiPathDisks.sh --ceph-raw-disk-name name_ceph_raw_disk
Note:
  • An Azure known issue incorrectly marks the Azure disk as non-SSD. If Azure is your cloud provider, and you want to configure the Objectstore disk, follow the instructions in Troubleshooting.
  • Vertical scaling of the existing disks is not supported. To increase the size of your in-cluster storage post-installation, add new raw disks.
Configuring the AI Center disk on selected machines
To configure the AI Center disk, run the following command on the machines where you plan to execute the training pipelines:
./configureUiPathDisks.sh --aicenter-disk-name name_of_aicenter_disk_to_partition./configureUiPathDisks.sh --aicenter-disk-name name_of_aicenter_disk_to_partition
To extend the storage for AI Center:
  • If you want to add a new AI Center disk, run the following command on the machine where you plan to add the disk:
    ./configureUiPathDisks.sh --aicenter-storage-extend name_of_new_aicenter_disk_to_attach./configureUiPathDisks.sh --aicenter-storage-extend name_of_new_aicenter_disk_to_attach
  • If you have expanded the existing AI Center disk, run the following command on the machine where the underlying AI Center disk is expanded:
    ./configureUiPathDisks.sh --aicenter-storage-extend./configureUiPathDisks.sh --aicenter-storage-extend
Configuring the hosting disk for the Automation Suite Robot package cache
This step is required for single-node setups without a dedicated Automation Suite Robot agent.
To host the Automation Suite Robot package cache on the server node, you need to create a disk of at least 10 GB:
./configureUiPathDisks.sh --volume name_of_data_disk --robot-package-cache./configureUiPathDisks.sh --volume name_of_data_disk --robot-package-cache
Note: It is recommended that the disk is backed up by LVM.
Configuring the bundle disk on the first server node for the in-cluster registry
This step is required in the following scenarios:
  • When performing an offline (air-gapped) installation;
  • When an external registry is not available.
To configure the bundle disk, run the following command only on the first server node:
./configureUiPathDisks.sh --bundle-disk-name name_of_bundle_disk ./configureUiPathDisks.sh --bundle-disk-name name_of_bundle_disk
Validating disk mounts
Note:
Make sure to add all mount points to the fstab file and to include the nofail option in those fstab entries so that it does not affect the VM boot in case of failure.
To validate that /etc/fstab is correctly configured and can handle a reboot of the system, take the following steps, run the following command:
mount -afvmount -afv
You should get the following output:
# Servers
/datadisk/monitoring              : already mounted
/datadisk/insights                : already mounted
/var/lib/rancher/rke2/server/db   : already mounted
# Servers or agents
/opt/UiPathAutomationSuite        : already mounted
/var/lib/rancher                  : already mounted
/var/lib/kubelet                  : already mounted
# In case of an offline environment, only on the primary server node
/uipath                           : already mounted
# Additional mount point is require if customer is installing offline with internal registry
/datadisk/registry                : already mounted
# Additional mount point is require if customer is using in-cluster objectstore
/datadisk/objectstore             : already mounted# Servers
# Servers or agents
