- Overview
 - Requirements
 - Deployment templates
 - Step 2: Configuring the OCI-compliant registry for offline installations
 - Step 3: Configuring the external objectstore
 - Step 4: Configuring High Availability Add-on
 - Step 5: Configuring SQL databases
 - Step 6: Configuring the load balancer
 - Step 7: Configuring the DNS
 - Step 8: Configuring the disks
 - Step 9: Configuring kernel and OS level settings
 - Step 10: Configuring the node ports
 - Step 11: Applying miscellaneous settings
 - Step 13: Generating cluster_config.json
 - Certificate configuration
 - Database configuration
 - Kerberos authentication configuration
 - Monitoring configuration
 - Cluster administration
- Managing products
 - Migrating from in-cluster to external High Availability Add-on
 - Migrating to an external OCI-compliant registry
 - Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
 - Monitoring and alerting
 - Migration and upgrade
 - Step 8: Deleting the default tenant
 - Upgrading Automation Suite
 - Executing the upgrade
- Using the Orchestrator Configurator Tool
 - Orchestrator appSettings
 - Configuring appSettings
 - Troubleshooting
 - How to clear Redis data
 - How to enable Istio logging
 - How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
 - How to forward application logs to Splunk
 - How to clean up unused Docker images from registry pods
 - Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
 - RKE2 not getting started due to space issue
 - In-place upgrade timeouts
 - AI Center provisioning failure after upgrading to 2023.10 or later
 - SQL validation fails during upgrade
 - Longhorn REST API endpoint upgrade/reinstall error
 - ArgoCD login failed
 - Redis probe failure
 - RKE2 server fails to start
 - Pods stuck in Init:0/X
 - Failure to configure email alerts post upgrade
 - No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
 - Failed status when creating a data labeling session
 - Failed status when trying to deploy an ML skill
 - Migration job fails in ArgoCD
 - Handwriting recognition with intelligent form extractor not working
 - Failed ML skill deployment due to token expiry
 - After Disaster Recovery Dapr is not working properly for Process Mining
 - Configuring Dapr with Redis in cluster mode
 - Exploring Logs
 - Exploring summarized telemetry
Before running any kubectl commands, make sure to enable kubectl. This allows you to run commands for retrieving passwords and configuration details for the cluster.
To enable kubectl, run the following command:
sudo su -
export KUBECONFIG="/etc/rancher/rke2/rke2.yaml" \
&& export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin"sudo su -
&& export PATH="$PATH:/usr/local/bin:/var/lib/rancher/rke2/bin"The installation process generates self-signed certificates on your behalf. These certificates will expire in 90 days, and you must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
For instructions, see Managing certificates.
If you try to access the cluster with a web browser, and the certificates are not from a trusted CA, then you will see a warning in the browser. You can rectify this by importing and trusting the cluster SSL certificate on the client computer running the browser.
To manage certificates, take the following steps:
The Cluster Administration portal is a centralized location where you can find all the resources required to complete an Automation Suite installation and perform common post-installation operations. For details, see Getting started with the Cluster Administration portal.
To access the Cluster Administration portal, take the following step:
https://${CONFIG_CLUSTER_FQDN}/uipath-management.The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all of your Automation Suite areas: administration pages, platform-level pages, product-specific pages, and user-specific pages.
To access Automation Suite, take the following steps:
The host portal is for system administrators to configure the Automation Suite instance. The settings that you configure from this portal are inherited by all your organizations, and some can be overwritten at the organization level.
To access host administration, take the following steps:
You can use the ArgoCD console to manage installed products.
Depending on the operations you want to carry out in ArgoCD, you can use two types of accounts to access the console:
- the read-only account in basic scenarios
 - admin account in advanced scenarios
For more details on ArgoCD and how you can access it, see Managing the cluster in ArgoCD.
You can access the Automation Suite monitoring tools individually using the following URLs:
                                     Application  |
                                     Tool  |
                                     URL  |
                                     Example  |
                                     Metrics  |
                                     Prometheus  |
                                     Dashboard  |
                                     Grafana  |
                                     Alert Management  |
                                     Alert Manager  |
Monitoring tool authentication
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
- Username: admin
 - Password: to retrieve the password , run the following command:
kubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -dkubectl get secrets/dex-static-credential -n uipath-auth -o "jsonpath={.data['password']}" | base64 -d
Dex authentication
To update the default password used for Dex authentication while accessing the monitoring tools, take the following steps.
Dex is a basic authentication method layered over the monitoring tools. Therefore, updating the Dex password does not impact the passwords for the monitoring tools. In this scenario, the passwords for the monitoring tools remain the same as before.
                        Run the following command by replacing
newpasswordwith your new password:password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath-auth --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]" -
Run the following command to update the password:
./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -f --accept-license-agreement./install-uipath.sh -i /opt/UiPathAutomationSuite/cluster_config.json -o ./output.json -f --accept-license-agreement
You can access the database connection strings for each service as follows:
kubectl -n uipath get secret aicenter-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret orchestrator-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret automation-hub-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret automation-ops-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret insights-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret platform-service-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret test-manager-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decodekubectl -n uipath get secret aicenter-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode
kubectl -n uipath get secret test-manager-secrets -o jsonpath='{.data.sqlConnectionString}' | base64 --decode- Enabling kubectl
 - Managing certificates
 - Accessing the Cluster Administration portal
 - Accessing Automation Suite general interface
 - Accessing host administration
 - Accessing ArgoCD
 - Accessing the monitoring tools
 - Overview
 - Monitoring tool authentication
 - Dex authentication
 - Accessing service database connection strings
