- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
The Automation Suite side-by-side upgrade allows you to perform upgrade operations safely using a parallel environment instead of upgrading in place.
This method allows administrators to switch traffic from the old Automation Suite cluster (for example, the blue deployment) to the new Automation Suite cluster (for example, the green deployment) after verifying the new deployment. If you detect a problem, you can roll back to the old deployment quickly.
When performing a side-by side upgrade, the two parallel clusters share one single license.
- If AI Center is enabled, make sure you meet the CUDA requirements.
- Hardware requirements, depending on the model that you chose:
- Side-by-side upgrade (identically sized target cluster) - Both the source and the target environments must meet the same hardware and software requirements.
- Side-by-side upgrade (single node start) - You can setup a single node target cluster and then scale it up. Ensure that you meet the hardware requirements suggested by the Automation Suite Install Sizing Calculator based on your product selection and usage details.
- Software requirements: Both the source and the target environments must meet the same hardware and software requirements.
Data |
Upgrade mechanism | |
| Status | Responsibility | |
SQL |
Retained |
Customer |
| FQDN |
Retained; optional You must choose a new FQDN for the new cluster. Optionally, you can revert to the previous FQDN if needed. | Customer |
| On-demand bundles |
Not migrated Run a script to see which bundles are in the cluster. Manually seeding is needed. | Customer |
| Certificates |
Not migrated You must bring certificates as part of the new cluster installation. | Customer |
| Cluster configuration |
Not migrated You must generate
cluster_config.json from the original source cluster so that you map the same services to the new cluster installation.
| Customer |
| Custom alerts and dashboards created by users |
Not migrated You must reconfigure the custom alerts and dashboards post-upgrade. | Customer |
| Application logs / Prometheus streaming configuration created by users |
Not migrated You must reconfigure application log and Prometheus streaming. | Customer |
| Dynamic workloads |
Depends on application AI Center training jobs are lost; Skills are retained. |
Skills (script needed to be executed after upgrade): UiPath® Training jobs: Customer |
Objectstore |
Retained |
In-cluster objectstore (Ceph): UiPath® External objectstore: Customer |
Insights |
Retained |
UiPath® |
MongoDB data |
Retained MongoDB data is moved to the target SQL. |
UiPath® |
RabbitMQ |
Not needed |
UiPath® |
| Monitoring (data) |
Not needed Monitoring data does not apply to the new cluster. Important: If you do not use the built-in monitoring components, you must set up external monitoring components after the migration
upgrade.
| N/A |
| Docker registry |
Not needed You must install an in-cluster docker registry or bring an external docker registry. | N/A |
Upgrade process steps |
1 |
Prepare the new cluster:
2 |
Migrate the data to the new cluster:
3 |
Complete the upgrade:
| 4 | Scaling the
target cluster - applicable only if you have opted for Side-by-side
upgrade (single node start):
We offer two models for side-by-side upgrades:
- Side-by-side upgrade (identically sized target cluster):
- Requires the target cluster to have the same hardware resources as the source cluster.
- Ready for traffic once:
Data migration is complete.
Sanity checks are successful.
- Side-by-side upgrade (single node start):
- Starts with a single-node setup, then scales up to an HA setup. This reduces the initial hardware requirements needed for side-by-side upgrade.
- Hardware for single-node setup must meet the recommendations of the Capacity Calculator for the single node setup.
- For scaling:
- Nodes from the source cluster can be decommissioned and added to the target cluster.
- Data migration is complete.
- Cluster is scaled to multi-node.
- Sanity checks are successful.
| Side-by-side upgrade (identically sized target cluster) | Side-by-side upgrade (single node start) | |
| Hardware requirements | Requires identical hardware for both source and target clusters. | Starts with minimal hardware, scaling up as needed. |
| Downtime | Minimal downtime due to fully redundant target environment. | Higher downtime due to node scaling operations. |
| Impact on source cluster | No impact. | Source nodes can be decommissioned and joined to the target cluster. |
| Rollback process | Simple rollback as the source remains untouched. | If scaling operation fails in the target cluster, rollback involves reintegrating nodes into the source cluster. |
| Cost impact | Higher costs due to duplicate infrastructure. | Lower costs with reduced initial hardware requirements. |
