Last updated May 22, 2026
Encrypting the SQL Server
To provide an additional layer of security to the data at rest in your SQL Server, you can use Transparent Data Encryption.
Note:
Transparent Data Encryption does not concern data in transit or in use. That means that if you run any queries on the database, retrieved information is unencrypted.
For details on how to encrypt your data using Transparent Data Encryption, refer to Microsoft documentation.
Encrypting the connection to SQL Server
To ensure the security of data that is in transit between the UiPath® web application and the SQL Server database, you can configure an SSL encrypted connection between the two.
For details on how to enable an encrypted connection to the database engine using the SQL Server Configuration Manager, refer to Microsoft documentation.
For details on how to encrypt a connection on a cloud database using Azure SQL Database, refer to Microsoft documentation.
  • Encrypting the SQL Server
  • Encrypting the connection to SQL Server
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
