Last updated Nov 13, 2025
Health endpoints
To effectively monitor the health of your Automation Suite services, you can use the health endpoints available in this section. These endpoints allow you to quickly verify if a service is operating correctly.
The following table lists the Automation Suite products and services and their respective health endpoints.
ServiceHealth endpoint(s)
Platform
  • https://<automation-suite-fqdn>/pap_/health
  • https://<automation-suite-fqdn>/pdp_/health
  • https://<automation-suite-fqdn>/identity_/.well-known/openid-configuration
  • https://<automation-suite-fqdn>/identity_/web/
  • https://<automation-suite-fqdn>/lease_/health/
  • https://<automation-suite-fqdn>/license_/health
  • https://<automation-suite-fqdn>/organization_/health
  • https://<automation-suite-fqdn>/portal_/portal/shallow/healthStatus
  • https://<automation-suite-fqdn>/audit_/health
  • https://<automation-suite-fqdn>/resourcecatalog_/health
Action Center
  • https://<automation-suite-fqdn>/actions_/
  • https://<automation-suite-fqdn>/bupporxyservice_/health/ready
  • https://<automation-suite-fqdn>/processes_/
AI Center
  • https://<automation-suite-fqdn>/aifabric_/ai-app
  • https://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/ready
  • https://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/ready
  • https://<automation-suite-fqdn>/aistorage_/health
Apps
  • https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Automation Hub
  • https://<automation-suite-fqdn>/automationhub_/fd-api/v1/ping
  • https://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Data Service
  • https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/health
  • https://<automation-suite-fqdn>/dataservice_/assets
Document Understanding
  • https://<automation-suite-fqdn>/du_/api/documentmanager/health
  • https://<automation-suite-fqdn>/du_/api/storage/health
  • https://<automation-suite-fqdn>/du_/api/eventservice/health
  • https://<automation-suite-fqdn>/du_/metering/alive
  • https://<automation-suite-fqdn>/du_/ocr/info/ready
  • https://<automation-suite-fqdn>/du_/extended-ocr/ready
  • https://<automation-suite-fqdn>/du_/classify/MLclassification/info/ready
  • https://<automation-suite-fqdn>/du_/svc/formextractor/info
  • https://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Insights
  • https://<automation-suite-fqdn>/insights_/health
Integration Services
  • https://<automation-suite-fqdn>/connections_/schedulerstatus
  • https://<automation-suite-fqdn>/connections_/dispatcherstatus
  • https://<automation-suite-fqdn>/elements_/v1/elements/health
  • https://<automation-suite-fqdn>/elements_/elements/api-v2/tickle
Notification Service
  • https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readiness
  • https://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator
  • https://<automation-suite-fqdn>/orchestrator_/api/health
Robotube
  • https://<automation-suite-fqdn>/robotube_/healthz
Test Manager
  • https://<automation-suite-fqdn>/testmanager_/api/health/live
Checking service health
To check the health of a specific service, send a request to its corresponding endpoint, as show in the following example.
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/healthcurl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
A successful response with an HTTP status code 200 indicates that the service is healthy.
  • Checking service health
