Last updated Nov 13, 2025
Offline installation fails because of missing binary
During offline installation, at the fabric stage, the execution fails with the following error message:
Error: overlay: can't stat program "/usr/bin/fuse-overlayfs": stat /usr/bin/fuse-overlayfs: no such file or directoryError: overlay: can't stat program "/usr/bin/fuse-overlayfs": stat /usr/bin/fuse-overlayfs: no such file or directory
Solution
You need to remove the line containing the mount_program key from the podman configuration /etc/containers/storage.conf.
Ensure you remove the line rather than comment it out.
  • Description
  • Solution
