- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Redis startup blocked by antivirus
- Exploring Logs
- Exploring summarized telemetry
This step is mandatory for a multi-node HA-ready production deployment or a single-node evaluation deployment with a dedicated GPU node.
If you are configuring a single-node evaluation deployment without a dedicated GPU node, proceed to Configuring Azure SQL.
If you are using the Azure Internal Load Balancer (LB) for deployments, you can encounter issues with the calls from the backend Virtual Machine (VM) to the LB frontend IP. The issues occur due to source IP and MAC address mismatch of the network packet. This prevents the recipient from working out the correct response path, resulting in the failure of calls from the VM to the LB. For more details, see Azure Load Balancer Components limitations and Backend Traffic Troubleshooting.
Make sure to repeat these steps for all virtual networks corresponding to each node.
The recommended configuration is to add two backend pools, as follows:
- one backend pool that includes all server nodes (referred to as the Server Pool);
- one backend pool with all server and agent nodes (referred to as the Node Pool in our documentation).
kubeapi-probe, whereas the Node Pool is associated with the https-probe.
443, 6443, and 9345.
