Automation Hub User Guide
Last updated Jun 26, 2025
Component Statuses
Status
Component Visible for
Draft
Author
  • The author uploaded a component but does not submit it.
  • The curator rejected the component in the curation flow with - needs update reason.
  • The author submitted the component but then withdrawn it.
Submitted
Author
Component Curators
The author has uploaded a component and submit it. The component remains in this state until the curation process is initiated.
In Review
Author
Assigned Component Curator
The curator has picked-up the component from the Manage Components list and started curating it.
Published
All Users
The curator finishes the curation process and decides to publish the component.
Rejected Permanently
Author
Component Curators
The curator finishes the curation process and decides to permanently reject the component.
Rejected Needs Update
Author
Component Curators
  • The curator finishes the curation process and decides to send the component back to the author with recommendation for updates.
  • The status is similar to the draft one, only that this one is used to warn the author that they need to update the component before submitting the component again.
Archived
Author
Users who have downloaded the component
The author decides to archive the component from My Components - uploads.
