Automation Hub api guide
Input for Phase
Input parameter values for the Phase field in Automation Hub API calls, with notes on correct key usage in POST phase and status updates.
Note:
For the POST call made to update an idea phase and status do not use the phase or status keys.
KeyPhase namePhase ID
IDEAIdea1
ASSESSMENTAssessment2
QUALIFICATIONQualification3
ANALYSISAnalysis4
SOLUTION_DESIGNSolution Design5
DEVELOPMENTDevelopment6
TESTINGTesting7
HYPERCAREHypercare8
LIVELive9
BUSINESS_REVIEWBusiness Review10
TECHNICAL_REVIEWTechnical Review11
Example: phase=2
UI Correspondent​
  • Automation Phase and Status
  • UI Correspondent​
Connect
Stay updated
