Automation Hub api guide
Delete an automation using OpenAPI
Delete an automation from Automation Hub using the OpenAPI DELETE endpoint.
Delete an automation from Automation Hub by calling the DELETE /api/v1/openapi/automations/{id} endpoint.
Prerequisites​
  • You have an active Automation Hub API token. For instructions, see Generate your Token from Automation Hub.
  • You know the numeric ID of the automation you want to delete. You can retrieve it from the automation's URL in Automation Hub or via a GET /api/v1/openapi/automations call.
  • You have the System Admin or Program Manager role.
Delete an automation​
  1. Construct the request URL using the automation ID:
    DELETE https://{baseUrl}/api/v1/openapi/automations/{id}
  2. Include the required authentication header:
    HeaderValue
    x-ah-openapi-app-keyYour Automation Hub API token
    x-ah-openapi-authopenapi
    Content-Typeapplication/json
  3. Optionally include a comment in the request body:
      "comment": "Removing duplicate entry."
  4. Send the request.
Results​
A successful deletion returns HTTP 200. The automation is permanently removed from the tenant and no longer appears in Automation Hub.
Error codes​
CodeMeaning
400Bad request — the request body is malformed or a required field is invalid.
404Not found — no automation with the specified ID exists in the tenant.
Example: delete multiple automations using a script​
Use the following PowerShell script to delete a list of automations by ID:
$baseUrl  = "https://<your-tenant>.automation-hub.uipath.com"
$appKey   = "<your-api-token>"
$ids      = @(1001, 1002, 1003)
$comment  = "Bulk cleanup"
foreach ($id in $ids) {
    $response = Invoke-RestMethod `
        -Method Delete `
        -Uri "$baseUrl/api/v1/openapi/automations/$id" `
        -Headers @{
            "x-ah-openapi-app-key" = $appKey
            "x-ah-openapi-auth"    = "openapi"
            "Content-Type"         = "application/json"
        -Body (ConvertTo-Json @{ comment = $comment })
    Write-Host "Deleted $id — Status: $($response.StatusCode)"
        -Method Delete `
        -Headers @{
For more information, see the API References page.
Connect
Stay updated
