Automation Hub api guide
Input for Collaborators
Input parameter values for the Collaborators field in Automation Hub API calls, used to retrieve users assigned collaborator roles on a specific automation idea.
The GET Collaborators call allows users to retrieve all the users assigned with a collaborator role within a specific automation idea.
Note:
As an input parameter use the automation ID, in order to identify the Automation Idea for which you want to retrieve the list of collaborators.
KeyValueUse Case
collaboratorsAutomation IDGET request parameter
Example: collaborators=72 where 72 is the automation ID
UI Correspondent: Collaborators.
Connect
Stay updated
