- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
OUT OF SUPPORT
Last updated Feb 25, 2025
The following example shows
input.json
with all products enabled, mandatory and optional configuration parameters for Automation Suite on EKS. You can use this
as reference and make changes as per your environment requirements.
Note that the minimum UiPath® product selection requires
platform
to be enabled. Make sure to replace all the username and passwords, including SQL connection strings.
"kubernetes_distribution": "eks",
"install_type": "online",
"profile": "ha",
"registries": {
"docker": {
"url": "registry.uipath.com"
"helm": {
"fqdn": "automationsuite.mycompany.com",
"admin_username": "admin",
"admin_password": "-----",
"fips_enabled_nodes": false,
"fabric": {
"redis": {
"hostname": "redis-cache.mycompany.com",
"password": "redispassword",
"port": 6380,
"tls": true
"external_object_storage": {
"enabled": true,
"create_bucket": true,
"storage_type": "s3",
"fqdn": "s3.us-east-1.amazonaws.com",
"port": 443,
"region": "us-east-1",
"access_key": "Accesskey",
"secret_key": "secret_vkey",
"use_instance_profile": false,
"bucket_name_prefix": "myprefix",
"bucket_name_suffix": "mysuffix"
"ingress": {
"service_annotations": {
"service.beta.kubernetes.io/aws-load-balancer-backend-protocol": "ssl",
"service.beta.kubernetes.io/aws-load-balancer-nlb-target-type": "ip",
"service.beta.kubernetes.io/aws-load-balancer-type": "nlb",
"service.beta.kubernetes.io/aws-load-balancer-scheme": "internet-facing",
"service.beta.kubernetes.io/aws-load-balancer-eip-allocations": "74.10.23.8"
"gateway_selector": {
"istio": "ingressgateway"
"exclude_components": [],
"server_certificate": {
"tls_cert_file": "",
"tls_key_file": "",
"ca_cert_file": ""
"additional_ca_certs": "",
"sql": {
"create_db": false,
"server_url": "",
"port": "",
"username": "",
"password": ""
"orchestrator": {
"enabled": true
"processmining": {
"enabled": true
"insights": {
"enabled": true,
"enable_realtime_monitoring": false
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"aicenter": {
"enabled": true
"documentunderstanding": {
"enabled": true
"test_manager": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"integrationservices": {
"enabled": false
"studioweb": {
"enabled": false
"dataservice": {
"enabled": true
"asrobots": {
"enabled": true
"storage_class": "as-storage-class",
"storage_class_single_replica": "storage-class-single-replica",
"platform": {
"enabled": true
"sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1443;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={sqlpassword};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com",
"sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1443;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={sqlpassword};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com",
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:[email protected]:1443/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server",
"telemetry_optout": false
"profile": "ha",
"registries": {
"docker": {
"helm": {
"fabric": {
"redis": {
"port": 6380,
"tls": true
"enabled": true,
"port": 443,
"ingress": {
"tls_key_file": "",
"ca_cert_file": ""
"sql": {
"create_db": false,
"server_url": "",
"port": "",
"username": "",
"password": ""
"orchestrator": {
"enabled": true
"processmining": {
"enabled": true
"insights": {
"enabled": true,
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"aicenter": {
"enabled": true
"enabled": true
"test_manager": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"enabled": false
"studioweb": {
"enabled": false
"dataservice": {
"enabled": true
"asrobots": {
"enabled": true
"platform": {
"enabled": true
