- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Rotating Blob Storage Credentials
- Disabling use of pre-signed URLs when uploading data to Amazon S3 storage
- Configuring process app security
- Setting up Kerberos authentication with basic MSSQL authentication for Process Mining
- Troubleshooting
OUT OF SUPPORT
Last updated Feb 25, 2025
Note:
When you are performing a new installation and you want to use Kerberos authentication, it is strongly recommended to configure
process app security as
single_account
. Refer to Configuring process app security for details.
When you want to use Kerberos authentication for login to Automation Suite and use basic MSSQL
authentication for Process Mining you need to add the following in the
processmining
section in the input.json
file.
"kerberos_auth_config": {
"enabled": false
"enabled": false
The following code shows an example
processmining
section with Kerberos authentication with basic MSSQL authentication for Process Mining.
"processmining": {
"enabled": true,
"enabled": false
"sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:password%[email protected]:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server",
"warehouse": {
"sql_connection_str": "Server=tcp:servername.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User ID=username;Password=Password@password;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://username%servername.database.windows.net:Password%[email protected]:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server"
"processmining": {
"enabled": true,
"enabled": false
"warehouse": {
