- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
OUT OF SUPPORT
Last updated Feb 25, 2025
The following an example shows an input.json file with all the products enabled, as well as the mandatory and optional configuration parameters for Automation Suite on
AKS. You can use the example as reference and make changes according to your environment requirements.
Note that the minimum UiPath® product selection requires the platform services to be enabled. Make sure to replace FQDNs, hostnames, usernames and passwords, and SQL connection strings with your own configurations.
"registries": {
"docker": {
"url": "registry.uipath.com"
"helm": {
"fqdn": "ci-asaks4002399.devtest-sl-ea.infra.uipath-dev.com",
"profile": "ha",
"fabric": {
"redis": {
"hostname": "ci-asaks4002399.redis.cache.windows.net",
"password": "REDIS_PASSWORD_PLACEHOLDER",
"port": 6380,
"tls": true
"external_object_storage": {
"enabled": true,
"storage_type": "azure",
"account_key": "----",
"account_name": "----",
"bucket_name_prefix": "",
"bucket_name_suffix": "",
"azure_fqdn_suffix": "core.windows.net",
"use_managed_identity": false
"kubernetes_distribution": "aks",
"sql_connection_string_template": "Server=tcp:ci-asaks4002399.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User [email protected];Password='SQL_PASSWORD_PLACEHOLDER';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
"sql_connection_string_template_jdbc": "jdbc:sqlserver://ci-asaks4002399.database.windows.net;database=DB_NAME_PLACEHOLDER;[email protected];password={SQL_PASSWORD_PLACEHOLDER};encrypt=true;trustServerCertificate=false;hostNameInCertificate=*.database.windows.net;loginTimeout=30;",
"sql_connection_string_template_odbc": "SERVER=ci-asaks4002399.database.windows.net;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=mssqladminun;PWD={SQL_PASSWORD_PLACEHOLDER};Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=ci-asaks4002399.database.windows.net",
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://mssqladminun%40ci-asaks4002399.database.windows.net:[email protected]:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=no&Encrypt=yes",
"admin_username": "admin",
"admin_password": "----",
"dataservice": {
"enabled": true,
"bucket_name": "uipath-as-dataservice"
"orchestrator": {
"enabled": true,
"bucket_name": "uipath-as-orchestrator"
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"bucket_name": "uipath-as-processmining"
"enabled": true
"insights": {
"enabled": true,
"bucket_name": "uipath-as-platform"
"task_mining": {
"bucket_name": "uipath-as-taskmining"
"enabled": true
"automation_hub": {
"enabled": true,
"automation_ops": {
"enabled": true,
"aicenter": {
"enabled": true
"documentunderstanding": {
"enabled": true
"test_manager": {
"enabled": true,
"action_center": {
"enabled": true,
"apps": {
"enabled": true,
"asrobots": {
"packagecaching": true,
"packagecachefolder": "/uipath_asrobots_package_cache",
"enabled": true
"storage_class": "managed-premium",
"storage_class_single_replica": "azurefile-csi",
"infra": {
"docker_registry": {}
"ingress": {
"service_annotations": {
"service.beta.kubernetes.io/azure-load-balancer-internal": "true"
"snapshot": {
"enabled": true,
"aks_infra_resource_group": "MC_ci-asaks4002399_ci-asaks4002399_eastus",
"cloud_name": "AzurePublicCloud",
"resource_group": "ci-asaks4002399",
"auth_mode": "ServicePrincipal",
"subscription_id": "b65b0225-ce9b-4a79-9dd9-c00071d40d64",
"tenant_id": "d8353d2a-b153-4d17-8827-902c51f72357",
"account_name": "storaccid2547865",
"bucket_name": "uipath-backup",
"client_id": "1fbd7d95-5f8c-4f70-90a6-fdf20310d10e",
"client_secret": "----"
"platform": {
"enabled": true
"registries": {
"docker": {
"helm": {
"profile": "ha",
"fabric": {
"redis": {
"port": 6380,
"tls": true
"enabled": true,
"dataservice": {
"enabled": true,
"orchestrator": {
"enabled": true,
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"enabled": true
"insights": {
"enabled": true,
"task_mining": {
"enabled": true
"automation_hub": {
"enabled": true,
"automation_ops": {
"enabled": true,
"aicenter": {
"enabled": true
"enabled": true
"test_manager": {
"enabled": true,
"action_center": {
"enabled": true,
"apps": {
"enabled": true,
"asrobots": {
"enabled": true
"infra": {
"ingress": {
"snapshot": {
"enabled": true,
"platform": {
"enabled": true
