- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
The installation process generates self-signed certificates on your behalf. You should replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes.
uipathctl CLI tool to update certificates post-installation. For details, see uipathctl documentation.
To generate the CSR and the private key, run the following command:
# copy the machine openssl configuration locally
cp /etc/pki/tls/openssl.cnf ./openssl.tmp.cnf
# Replace the [AUTOMATION_SUITE_FQDN] value. For example, "automationsuite.corp.com"
AS_FQDN=[AUTOMATION_SUITE_FQDN]
cat >> ./openssl.tmp.cnf <<EOF
[SAN]
subjectAltName=DNS:$AS_FQDN,DNS:alm.$AS_FQDN,DNS:monitoring.$AS_FQDN,DNS:registry.$AS_FQDN,DNS:objectstore.$AS_FQDN,DNS:insights.$AS_FQDN
EOF
# create the certificate request
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csr# copy the machine openssl configuration locally
[SAN]
EOF
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csrYour IT team uses the obtained values to generate a signed certificate. The generated private key remains local.
To view more information about updating the TLS certificates, run the following command:
uipathctl config update-tls-certificates --helpuipathctl config update-tls-certificates --helpOutput:
Manage tls certificates
Usage:
uipathctl config tls-certificates [flags]
uipathctl config tls-certificates [command]
Available Commands:
get Get the current tls certificates
update Update tls certificates
Flags:
-h, --help help for tls-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
************************************************************************************Finding the TLS certificates
istio-ingressgateway-certs name in the
istio-system namespace.
See the certificate files in the following list:
Server TLS certificate is stored as
tls.crt -
Server TLS private key as
tls.key -
CA bundle is stored as
ca.crt
You can verify the secrets using the following command:
kubectl -n istio-system get secrets istio-ingressgateway-certs -o yamlkubectl -n istio-system get secrets istio-ingressgateway-certs -o yamlCertificates are also stored in the UiPath namespace. This is applicable to every UiPath® product that needs certificate information to trust incoming calls. For details, see Understanding the container architecture related to certificates.
Updating the TLS certificates
You must decrypt the certificate key before updating the server certificate. Skipping the decryption step would result in an error.
To decrypt the certificate key, run the following command:
# replace /path/to/encrypted/cert/key to absolute file path of key
# replace /path/to/decrypt/cert/key to store decrypt key
# Once prompted, please entry the passphrase or password to decrypt the key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/key# replace /path/to/encrypted/cert/key to absolute file path of key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/keyuipathctl command. You need the path to each of the three certificate files. All the certificate file should be in pem format.
Certificate Authority Bundle - This bundle should contain only the chain certificates used to sign the TLS server certificate. The certificate provided in the
--cacertoption should not include the leaf certificates. The chain limit is up to nine certificates. -
Server Certificate - Public server certificate
Private key - Private key for server certificate
uipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.keyuipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.keyAccessing the TLS certificate
To print out the certificate files, run the following command:
uipathctl config tls-certificates getuipathctl config tls-certificates getTo view more information about additional CA certificates, run the following command:
uipathctl config additional-ca-certificates --helpuipathctl config additional-ca-certificates --helpOutput:
Manage additional ca certificates
Usage:
uipathctl config additional-ca-certificates [flags]
uipathctl config additional-ca-certificates [command]
Available Commands:
get Get the current additional ca certificates
update Update additional ca certificates
Flags:
-h, --help help for additional-ca-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
***************************************************************************************Updating the CA certificates
This command helps you update or replace the existing configured CA certificates.
uipathctl config additional-ca-certificates update --cacert additional_ca.crtuipathctl config additional-ca-certificates update --cacert additional_ca.crt--replace at the end.
.pem format and can have more than one certificate present in it.
Accessing the CA certificates
To download the already configured CA certificates, run the following command:
uipathctl config additional-ca-certificates get uipathctl config additional-ca-certificates getTo view more information about identity token-signing certificates, run the following command:
uipathctl config token-signing-certificates --helpuipathctl config token-signing-certificates --helpOutput:
Manage token signing certificates
Usage:
uipathctl config token-signing-certificates [flags]
uipathctl config token-signing-certificates [command]
Available Commands:
get Get the current token signing certificate
rotate Rotate token signing certificates
update Update future token signing certificate
Flags:
-h, --help help for token-signing-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
************************************************************************************Updating the certificate
To upload the new certificate to sign the token, run the following command:
The following command does not replace the existing token signing certificate.
.pem format.
uipathctl config token-signing-certificates update --cert server.crt --key server.keyuipathctl config token-signing-certificates update --cert server.crt --key server.keyRotating the certificate
To rotate or replace the old certificate with the new one, run the following command:
uipathctl config token-signing-certificates rotateuipathctl config token-signing-certificates rotateAfter rotation, restart deployments and stateful sets by running the following commands:
kubectl -n uipath rollout restart deploy
kubectl -n uipath rollout restart stskubectl -n uipath rollout restart deploy
kubectl -n uipath rollout restart stsAccessing the certificate
To download the current token signing certificate, run the following command:
uipathctl config token-signing-certificates getuipathctl config token-signing-certificates getThere should be alead time of approximately 24-48 hours between certificate update and rotate.
We need this lead time to keep supporting the authentication for cached token signed by old certificate.
Rotating the certificate too soon before the expiry of the cache token can result in downtime. In this case, you may have to restart all your robots.
- Generating a Certificate Signing Request (CSR) and a private key
- Managing the TLS certificate
- Finding the TLS certificates
- Updating the TLS certificates
- Accessing the TLS certificate
- Managing additional CA certificates
- Updating the CA certificates
- Accessing the CA certificates
- Managing identity token-signing certificates
- Updating the certificate
- Rotating the certificate
- Accessing the certificate
