- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
Last updated Nov 13, 2025
The following example shows
input.json with all products enabled, mandatory and optional configuration parameters for Automation Suite on EKS. You can use this
as reference and make changes as per your environment requirements.
Note that the minimum UiPath® product selection requires
platform to be enabled. Make sure to replace all the username and passwords, including SQL connection strings.
"kubernetes_distribution": "eks",
"install_type": "online",
"profile": "ha",
"registries": {
"docker": {
"url": "registry.uipath.com",
"username": "",
"password": ""
"helm": {
"username": "",
"password": ""
"fqdn": "automationsuite.mycompany.com",
"admin_username": "admin",
"admin_password": "password123",
"fips_enabled_nodes": false,
"fabric": {
"redis": {
"license": "", // fabric.redis.license must not be specified when fabric.redis.{hostname, password, port} are specified
"ha":false,
"hostname": "redis-cache.mycompany.com",
"password": "redispassword",
"port": 6380,
"tls": true
"pod_identity" : {
"enabled": true,
"aks_managed_identity_client_id": <client-id>
"external_object_storage": {
"enabled": true,
"create_bucket": true,
"storage_type": "azure",
"use_managed_identity": false,
"azure_fqdn_suffix": "core.windows.net",
"account_key": "secretkey",
"account_name": "as-storage-account",
// storage type s3 specific config:
"fqdn": null,
"port": null,
"region": "us-east-1",
"access_key": "",
"secret_key": "",
"use_instance_profile": true,
"bucket_name_prefix": "",
"bucket_name_suffix": ""
"ingress": {
"service_annotations": {
"service.beta.kubernetes.io/aws-load-balancer-backend-protocol": "ssl",
"service.beta.kubernetes.io/aws-load-balancer-eip-allocations": "<elastic_ip_id_0>,<elastic_ip_id_1>",
"service.beta.kubernetes.io/aws-load-balancer-nlb-target-type": "ip",
"service.beta.kubernetes.io/aws-load-balancer-scheme": "internet-facing",
"service.beta.kubernetes.io/aws-load-balancer-type": "nlb"
"gateway_selector": {
"istio": "ingressgateway"
"istioMinProtocolVersion": "TLSV1_3",
"disable_presigned_url": false,
"tolerations": [],
"exclude_components": [],
"server_certificate": {
"tls_cert_file": "",
"tls_key_file": "",
"ca_cert_file": ""
"additional_ca_certs": "",
"registry_ca_cert": "",
"identity_certificate": {
"saml_current_service_cert_file": "",
"saml_current_service_cert_pass": "",
"saml_future_service_cert_file": "",
"saml_future_service_cert_pass": "",
"ldap_cert_authority_file": ""
"sql": {
"create_db": false,
"server_url": "",
"port": "",
"username": "",
"password": ""
"infra": {
"bucket_name": "s3-sfd-ci-aseks3997852-common"
"dataservice": {
"bucket_name": "s3-sfd-ci-aseks3997852-dataservice"
"enabled": true
"platform": {
"enabled": true
"integrationservices": {
"queue_prefix": "<queuePrefix>",
"account_id":""
"enabled": true,
"studioweb": {
"enabled": true,
"orchestrator": {
"enabled": true,
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"bucket_name": "s3-sfd-ci-aseks3997852-processmining"
"enabled": true
"insights": {
"enabled": true,
"enable_realtime_monitoring": false,
"task_mining": {
"bucket_name": "s3-sfd-ci-aseks3997852-taskmining"
"enabled": true
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"aicenter": {
"bucket_name": "s3-sfd-ci-aseks3997852-common",
"port": 443,
"fqdn": "s3.eu-west-1.amazonaws.com"
"enabled": true
"documentunderstanding": {
"enabled": true
"test_manager": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"asrobots": {
"packagecaching": true,
"packagecachefolder": "/uipath_asrobots_package_cache",
"enabled": true
"storage_class": "ebs-sc",
"storage_class_single_replica": "efs-sc",
"proxy": {
"enabled": true,
"http_proxy": "<http://<PROXY-SERVER-IP>:<PROXY-PORT>",
"https_proxy": "<http://<PROXY-SERVER-IP>:<PROXY-PORT>",
"no_proxy": "paste list from Configuring the cluster section"
"sql_connection_string_template": "Server=tcp:mssql.mycompany.com,1443;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=sqladmin;Password='sqlpassword';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"sql_connection_string_template_jdbc": "jdbc:sqlserver://mssql.mycompany.com:1443;database=DB_NAME_PLACEHOLDER;user=sqladmin;password={sqlpassword};encrypt=true;trustServerCertificate=true;loginTimeout=30;hostNameInCertificate=mssql.mycompany.com",
"sql_connection_string_template_odbc": "SERVER=mssql.mycompany.com,1443;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=sqladmin;PWD={sqlpassword};Encrypt=yes;TrustServerCertificate=yes;Connection Timeout=30;hostNameInCertificate=mssql.mycompany.com",
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://sqladmin:[email protected]:1443/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server",
"postgresql_connection_string_template_sqlalchemy_pyodbc": "postgresql+psycopg2://sa:<password>@135.235.240.165:5432/DB_NAME_PLACEHOLDER",
"telemetry_optout": false
"profile": "ha",
"registries": {
"docker": {
"username": "",
"password": ""
"helm": {
"username": "",
"password": ""
"fabric": {
"redis": {
"ha":false,
"port": 6380,
"tls": true
"pod_identity" : {
"enabled": true,
"enabled": true,
"fqdn": null,
"port": null,
"access_key": "",
"secret_key": "",
"ingress": {
"tolerations": [],
"tls_key_file": "",
"ca_cert_file": ""
"sql": {
"create_db": false,
"server_url": "",
"port": "",
"username": "",
"password": ""
"infra": {
"dataservice": {
"enabled": true
"platform": {
"enabled": true
"account_id":""
"enabled": true,
"studioweb": {
"enabled": true,
"orchestrator": {
"enabled": true,
"testautomation": {
"enabled": true
"updateserver": {
"enabled": true
"processmining": {
"enabled": true
"insights": {
"enabled": true,
"task_mining": {
"enabled": true
"automation_hub": {
"enabled": true
"automation_ops": {
"enabled": true
"aicenter": {
"port": 443,
"enabled": true
"enabled": true
"test_manager": {
"enabled": true
"action_center": {
"enabled": true
"apps": {
"enabled": true
"asrobots": {
"enabled": true
"proxy": {
"enabled": true,
