Last updated Dec 4, 2025
How to uninstall Automation Suite
This section explains how to uninstall Automation Suite from EKS/AKS environments using the provided uninstall script.
You will learn how to prepare your system, execute the script, troubleshoot issues, and extend the functionality for custom requirements.
Understanding the script and requirements
This section gives you a high-level understanding of the uninstall script and outlines the prerequisites required to use it effectively.
The uninstall script supports selective deletion of Automation Suite components, dry-run simulations, verbose output, and the ability to exclude specific components via command-line flags or a JSON configuration file.
Prerequisites
This subsection lists the tools you must have installed in your environment to successfully run the uninstall script:
  • EKS/AKS:
    • kubectl
    • helm
  • Optional:
    • jq - used for JSON parsing
Downloading and preparing the script
To obtain the uninstall script and prepare it for execution, take the following steps:
  1. Download the uninstall.sh script.
  2. Make the script executable by running the following command:
    chmod +x uninstall.shchmod +x uninstall.sh
Running the script and using options
This section describes how to run the uninstall script, including command syntax, supported environments, and available flags.
You can run the script using the following command:
./uninstall.sh [DISTRIBUTION] [OPTIONS]./uninstall.sh [DISTRIBUTION] [OPTIONS]
You can use the following distribution options, based on your environments:
  • k8s: Use standard Kubernetes commands (default).
  • openshift: Use OpenShift commands and APIs.
The following table lists all the supported flags and arguments that you can use to customize the uninstall behavior for your specific environment.
OptionDescription
-h, --helpShow help information.
-d, --dry-runPreview changes without deleting anything.
-v, --verboseEnable detailed logging.
--excluded COMPONENTSComma-separated list of components to skip.
--clusterconfig FILEPath to a JSON config file for exclusions.
--istioNamespace NAMESPACEOverride default Istio namespace.
--uipathNamespace NAMESPACEOverride default UiPath namespace.
--argocdNamespace NAMESPACEOverride default ArgoCD namespace.
Using basic examples
This section provides simple example commands to help you quickly start using the uninstall script with minimal options.
# Exclude istio from deletion in k8s
./uninstall.sh k8s --excluded istio
# Exclude istio and argocd in OpenShift
./uninstall.sh openshift --excluded istio,argocd# Exclude istio from deletion in k8s
Using advanced combinations
This section presents advanced examples that combine multiple options for more flexible and powerful uninstall scenarios.
# Dry run to preview changes
./uninstall.sh openshift --dry-run
# Use a JSON config file
./uninstall.sh k8s --clusterconfig input.json
# Custom namespaces
./uninstall.sh openshift --uipathNamespace uipath-prod --istioNamespace custom-istio
# Combined options with verbosity
./uninstall.sh k8s --excluded gatekeeper,falco --clusterconfig input.json --verbose# Dry run to preview changes
# Custom namespaces
Configuring components and exclusions
This section outlines which components the script manages, how to exclude them, and what dependencies to consider.
Supported components
This section lists the Automation Suite components that the uninstall script is capable of managing and deleting:
  • istio - Service mesh components
  • istio_configure - Istio configuration
  • argocd - ArgoCD deployment
  • uipath - Core UiPath components
  • cert_manager - Certificate management
  • network_policies - Network policies
  • gatekeeper - Gatekeeper enforcement
  • falco - Gatekeeper enforcement
Using configuration files
This section shows how to configure component exclusions using a JSON file.
You can exclude components via JSON, as follows:
  "exclude_components": [
    "istio",
    "argocd",
    "gatekeeper"
    "istio",
    "argocd",
    "gatekeeper"
Understanding component dependencies
This section explains the relationships between components to help you avoid issues when excluding specific items.
Some components have dependencies on others:
  • If you keep uipath, consider also keeping istio and argocd.
  • If you keep cert_manager, consider also keeping uipath.
