Last updated Nov 13, 2025
Step 1: Saving the connection strings
Save the following information for further usage:
  • The connection string for the Orchestrator database in the standalone deployment;
  • The connection string for the Insights database in the standalone deployment;
  • The connection string for the AutomationSuite_Platform database in the Automation Suite deployment. You can retrieve the connection string from the input.json file, under the platform parameter.
