- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Step 8: Deleting the default tenant
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Test Automation SQL connection string is ignored
- EKS backup failure due to Velero version
Last updated Nov 13, 2025
If you encounter issues while upgrading Automation Suite or while migrating from a standalone UiPath® product to Automation Suite, see the following:
