OUT OF SUPPORT
Last updated Feb 24, 2025
Update the underlying directory connections
Disabling or changing the AD integration settings does not update the underlying directory connections properly.
Run the following command to update the SQL DirectoryConnections table entries, then restart the Identity pods:
UPDATE [identity].[DirectoryConnections] SET IsDeleted = 1, DeletionTime=GETUTCDATE() WHERE (Type='ad' OR Type='ldapad') AND IsDeleted=0UPDATE [identity].[DirectoryConnections] SET IsDeleted = 1, DeletionTime=GETUTCDATE() WHERE (Type='ad' OR Type='ldapad') AND IsDeleted=0
  • Update the underlying directory connections
