- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Following a cluster restore or rollback, AI Center, Orchestrator, Platform, Document Understanding or Task Mining might be unhealthy, with the RabbitMQ pod logs showing the following error:
[root@server0 UiPathAutomationSuite]# k -n rabbitmq logs rabbitmq-server-0
2022-10-29 07:38:49.146614+00:00 [info] <0.9223.362> accepting AMQP connection <0.9223.362> (10.42.1.161:37524 -> 10.42.0.228:5672)
2022-10-29 07:38:49.147411+00:00 [info] <0.9223.362> Connection <0.9223.362> (10.42.1.161:37524 -> 10.42.0.228:5672) has a client-provided name: rabbitConnectionFactory#77049094:2100
2022-10-29 07:38:49.147644+00:00 [erro] <0.9223.362> Error on AMQP connection <0.9223.362> (10.42.1.161:37524 -> 10.42.0.228:5672, state: starting):
2022-10-29 07:38:49.147644+00:00 [erro] <0.9223.362> PLAIN login refused: user 'aicenter-service' - invalid credentials
2022-10-29 07:38:49.147922+00:00 [info] <0.9223.362> closing AMQP connection <0.9223.362> (10.42.1.161:37524 -> 10.42.0.228:5672 - rabbitConnectionFactory#77049094:2100)
2022-10-29 07:38:55.818447+00:00 [info] <0.9533.362> accepting AMQP connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672)
2022-10-29 07:38:55.821662+00:00 [info] <0.9533.362> Connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672) has a client-provided name: rabbitConnectionFactory#2100d047:4057
2022-10-29 07:38:55.822058+00:00 [erro] <0.9533.362> Error on AMQP connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672, state: starting):
2022-10-29 07:38:55.822058+00:00 [erro] <0.9533.362> PLAIN login refused: user 'aicenter-service' - invalid credentials
2022-10-29 07:38:55.822447+00:00 [info] <0.9533.362> closing AMQP connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672 - rabbitConnectionFactory#2100d047:4057)[root@server0 UiPathAutomationSuite]# k -n rabbitmq logs rabbitmq-server-0
2022-10-29 07:38:55.822447+00:00 [info] <0.9533.362> closing AMQP connection <0.9533.362> (10.42.0.198:45032 -> 10.42.0.228:5672 - rabbitConnectionFactory#2100d047:4057)CrashLoopBackOff state due to the Mnesia table data write issue.
If all pods are running, take the following steps:
Delete the users in RabbitMQ:
kubectl -n rabbitmq exec rabbitmq-server-0 -c rabbitmq -- rabbitmqctl list_users -s --formatter json | jq '.[]|.user' | grep -v default_user | xargs -I{} kubectl -n rabbitmq exec rabbitmq-server-0 -c rabbitmq -- rabbitmqctl delete_user {}kubectl -n rabbitmq exec rabbitmq-server-0 -c rabbitmq -- rabbitmqctl list_users -s --formatter json | jq '.[]|.user' | grep -v default_user | xargs -I{} kubectl -n rabbitmq exec rabbitmq-server-0 -c rabbitmq -- rabbitmqctl delete_user {} -
Delete RabbitMQ application secrets in the UiPath namespace:
kubectl -n uipath get secret --template '{{range .items}}{{.metadata.name}}{{"\n"}}{{end}}' | grep -i rabbitmq-secret | xargs -I{} kubectl -n uipath delete secret {}kubectl -n uipath get secret --template '{{range .items}}{{.metadata.name}}{{"\n"}}{{end}}' | grep -i rabbitmq-secret | xargs -I{} kubectl -n uipath delete secret {} -
Delete RabbitMQ application secrets in the RabbitMQ namespace:
kubectl -n rabbitmq get secret --template '{{range .items}}{{.metadata.name}}{{"\n"}}{{end}}' | grep -i rabbitmq-secret | xargs -I{} kubectl -n rabbitmq delete secret {}kubectl -n rabbitmq get secret --template '{{range .items}}{{.metadata.name}}{{"\n"}}{{end}}' | grep -i rabbitmq-secret | xargs -I{} kubectl -n rabbitmq delete secret {} -
Sync
sfcoreapplication via ArgoCD and wait for the sync to complete: -
Perform a rollout restart on all applications in the UiPath namespace:
kubectl -n uipath rollout restart deploykubectl -n uipath rollout restart deploy
If some pods are in CrashLoopBackOff state, take the following steps:
Identify which RabbitMQ pods are stuck in
CrashLoopBackOffstate, and check the RabbitMQCrashLoopBackOffpod logs:kubectl -n rabbitmq get pods kubectl -n rabbitmq logs <CrashLoopBackOff-Pod-Name>kubectl -n rabbitmq get pods kubectl -n rabbitmq logs <CrashLoopBackOff-Pod-Name> -
Check the output of the previous commands. If the issue is related to the Mnesia table data write, you should see an error message similar to the following:
Mnesia('[email protected]'): ** ERROR ** (could not write core file: eacces) ** FATAL ** Failed to merge schema: Bad cookie in table definition rabbit_user_permission: '[email protected]' = {cstruct,rabbit_user_permission,set,[],['[email protected]','[email protected]','[email protected]'],[],[],0,read_write,false,[],[],false,user_permission,[user_vhost,permission],[],[],[],{{1667351034020261908,-576460752303416575,1},'[email protected]'},{{4,0},{'[email protected]',{1667,351040,418694}}}}, '[email protected]' = {cstruct,rabbit_user_permission,set,[],['[email protected]'],[],[],0,read_write,false,[],[],false,user_permission,[user_vhost,permission],[],[],[],{{1667372429216834387,-576460752303417087,1},'[email protected]'},{{2,0},[]}}Mnesia('[email protected]'): ** ERROR ** (could not write core file: eacces) ** FATAL ** Failed to merge schema: Bad cookie in table definition rabbit_user_permission: '[email protected]' = {cstruct,rabbit_user_permission,set,[],['[email protected]','[email protected]','[email protected]'],[],[],0,read_write,false,[],[],false,user_permission,[user_vhost,permission],[],[],[],{{1667351034020261908,-576460752303416575,1},'[email protected]'},{{4,0},{'[email protected]',{1667,351040,418694}}}}, '[email protected]' = {cstruct,rabbit_user_permission,set,[],['[email protected]'],[],[],0,read_write,false,[],[],false,user_permission,[user_vhost,permission],[],[],[],{{1667372429216834387,-576460752303417087,1},'[email protected]'},{{2,0},[]}} -
To fix the issue, take the following steps:
Find the number of RabbitMQ replicas:
rabbitmqReplicas=$(kubectl -n rabbitmq get rabbitmqcluster rabbitmq -o json | jq -r '.spec.replicas') -
Scale down the RabbitMQ replicas:
kubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": 0}}" --type=mergekubectl -n rabbitmq scale sts rabbitmq-server --replicas=0 -
Wait until all RabbitMQ pods are terminated:
kubectl -n rabbitmq get pod -
Check for pending volume snapshots:
kubectl get volumesnapshot -n rabbitmq <crashloopbackupoff_pod_pvc_name> | grep falsekubectl get volumesnapshot -n rabbitmq <crashloopbackupoff_pod_pvc_name> | grep false -
If any pending volume snapshot exists, delete it:
kubectl delete volumesnapshot -n rabbitmq <pending_volume_snapshot_name>kubectl delete volumesnapshot -n rabbitmq <pending_volume_snapshot_name> -
Find and delete the PVC of the RabbitMQ pod that is stuck in
CrashLoopBackOffstate:kubectl -n rabbitmq get pvckubectl -n rabbitmq delete pvc <crashloopbackupoff_pod_pvc_name> -
Scale up the RabbitMQ replicas:
kubectl -n rabbitmq patch rabbitmqcluster rabbitmq -p "{\"spec\":{\"replicas\": $rabbitmqReplicas}}" --type=merge -
Check if all RabbitMQ pods are healthy:
