- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
Tip:
The previous step is Step 2: Configuring the load balancer.
In this section, you will provision and configure an SQL Server.
Each service uses a DB with its own specifications.
- In the installation process, the default option is to give the installer access to the SQL Server so it can create the required databases.
- As an alternative option, you could also create the databases manually using the default DB names listed in Configuring Microsoft SQL Server (single-node evaluation or multi-node HA-ready production).
The next step is Step 4: Configuring the DNS.
