OUT OF SUPPORT
Last updated Feb 24, 2025
Unexpected Inconsistency; Run Fsck Manually
While installing or upgrading Automation Suite, if the MongoDB pods cannot mount to the PVC pods, the following error message is displayed:
UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY
Recovery steps
If you encounter the error above, follow the recovery steps below:
  1. SSH to the system by running the following command:
    ssh <user>@<node-ip>ssh <user>@<node-ip>
  2. Check the events of the PVC and verify that the issue is related to the PVC mount failure due to file error. To do this, run the following command:
    export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin
    kubectl get events -n mongodb
    kubectl get events -n longhorn-systemexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin
  3. Check the PVC volume mentioned in the event and run the fsck command.
    fsck -a <pvc-volume-name>
    Eg - fsck -a /dev/longhorn/pvc-5abe3c8f-7422-44da-9132-92be5641150afsck -a <pvc-volume-name>
  4. Delete the failing MongoDB pod to properly mount it to the PVC.
    kubectl delete pod <pod-name> -n mongodbkubectl delete pod <pod-name> -n mongodb
  • Recovery steps
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
