- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
If you experience issues specific to Kubernetes running on the cluster, you can directly uninstall the rke2 cluster. To do that, take the following steps:
Depending on your installation profile, run one of the following commands:
In an online setup, run the following script with elevated privileges, i.e.
sudo, on each node of the cluster. This will uninstall the nodes.function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete." -
In an offline setup, run the following script with elevated privileges, i.e.
sudo, on each node of the cluster. This will uninstall the nodes.function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/local/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/local/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/local/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/local/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/local/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/local/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/local/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/local/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."
Reboot the node after uninstall.
Important: When uninstalling one of the nodes from the cluster, you must run the following command:
kubectl delete node <node_name>. This removes the node from the cluster.
