test-manager
Test Manager user guide
General project settings
Available general settings for a Test Manager project, including default reporting time zone and custom test execution name formatting.
Open a project and navigate to Project Settings. The General tab allows you to configure general settings for that specific project.
Default reporting date time zone​
From the Default reporting date time zone dropdown, select the timezone that aligns with your location and reporting preferences.
The project dashboard will calculate reporting dates based on the selected default time zone. While test executions are still reported in UTC timezone for accuracy, this setting ensures that the project dashboard aligns with your preferred time zone.
Execution​
Under the Execution section, you can define a custom naming format for test executions in your project. If you don't set a custom format, the default format is used: {Execution.Type} - {TestSet.Name} - {Execution.StartTime|yyyyMMdd.HHmmss}.
In the Test execution name format field, enter the format for naming test executions. Use single curly braces to insert variables, for example, {TestSet.Name}. The following variables are available:
  • Execution.Type - the type of execution: manual or automated.
  • TestSet.Name - the name of the test set.
  • Execution.StartTime - the start time of the execution. Supports .NET date format notation, for example, {Execution.StartTime|yyyyMMdd.HHmmss}.
  • Custom fields of type Test Set.
  • Free text.
For example, a dynamic test execution name can look like {Execution.Type} - {TestSet.Name} - {Execution.StartTime|yyyyMMdd.HHmmss}. If a referenced custom field does not exist, the reference expression is displayed as-is in the execution name.
Note:
The execution name is set once when the test execution is created and is not updated automatically afterward. Users with the Project - Edit permission can edit the name manually. Leaving the field empty reverts to the default format.
  • Default reporting date time zone​
  • Execution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
