- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Performing database maintenance
- Configuring the FQDN post-installation
- Forwarding logs to external tools
- Guidelines on upgrading an Active/Passive deployment
- Guidelines on backing up and restoring an Active/Passive deployment
- Troubleshooting
Last updated May 30, 2025
The generated kubeconfig file must have only limited permissions to access another cluster's correct set of Kube objects.
To generate the base64-encoded kubeconfig file, run the following command:
uipathctl config kubeconfig get --multisite
Parameter |
Description |
--multisite | Generates the kubeconfig file with limited permissions. |
To update the kubeconfig file of another cluster and link both of them, run the following command:
uipathctl config kubeconfig set --secret "fgad8GDH9dbks" --multisite
Parameter |
Description |
--secret | Accepts the base64-encoded kubeconfig file. |
--multisite | Links the two clusters. |
