- Overview
 - Requirements
 - Pre-installation
 - Migration and upgrade
- Upgrading Automation Suite
 - Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
 - Monitoring and alerting
 - Cluster administration
 - Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
 - Pods in the uipath namespace stuck when enabling custom node taints
 - Unable to launch Automation Hub and Apps with proxy setup
 - Robot cannot connect to an Automation Suite Orchestrator instance
 - Log streaming does not work in proxy setups
 - Velero backup fails with FailedValidation error
 - Accessing FQDN returns RBAC: access denied error
The following table lists the third-party software compatible with the latest version of Automation Suite on AKS.
                               Prerequisites for Azure  |
                               Compatible versions  |
| Azure Kubernetes Service (AKS)
                               Architecture  |
                               x86  |
                               Ubuntu  |
                               22.04  |
                               Cloud Redis  |
                               Version 6  |
                               Microsoft SQL Server  |
                               Microsoft SQL Server 2016, 2017, 2019, and 2022, Standard and Enterprise editions. For product-specific version dependency, see SQL database.  |
                               PostgreSQL Note:
                              Process Mining on Automation Suite 2024.10.3 or higher.  |
                               PostgreSQL 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance.  |
                               Prometheus (if you bring your own)  |
                               3.5.0  |
                               Grafana (if you bring your own)  | 12.0.2 |
                               Alert Manager (if you bring your own)  |
                               0.28.1  |
                               FluentD/Fluent-bit (if you bring your own) helm-charts: logging-operator, logging-operator-logging  |
                               6.0.1  |
                               Gatekeeper (if you bring your own) helm-charts: gatekeeper  |
                               3.20.0  |
                               Velero (if you bring your own) helm-charts: velero  |
                               10.0.10  |
                               Cert Manager (if you bring your own) helm-charts: cert-manager  |
                               1.18.2  |
                               Istio (if you bring your own) helm-charts: istio-base  | 1.26.3 |
The following table lists the third-party software compatible with the latest version of Automation Suite on EKS.
                                  Prerequisites for AWS  |
| Elastic Kubernetes Service (EKS)
                                  Architecture  |
                                  x86  |
                                  RHEL  |
                                  8.8 for EKS 1.33  |
                                  Amazon Linux  |
                                  AL2 and AL2023 for all EKS versions except EKS 1.33 where only AL2023 is supported  |
                                  Bottlerocket  |
                                  1.19.2  |
                                  Elasticache  |
                                  version 6.2.6  |
                                  Database - RDS  |
                                  15.00.4236.7.v1  |
                                  Prometheus (if you bring your own)  | 3.5.0 |
                                  0.28.1  |
                                  6.0.1  |
                                  3.20.0  |
                                  10.0.10  |
                                  Cert Manager (if you bring your own) helm-charts: cert-manager  | 1.18.2 |
To receive UiPath® support for a particular Automation Suite Cumulative Update (CU), you must use both an Automation Suite version and a Kubernetes version that are currently supported.
The support calendar for Automation Suite is available in the Product lifecycle section of the Overview guide. For the Kubernetes support calendar, see the Kubernetes documentation.
Updating your Kubernetes cluster to a supported version may require updating Automation Suite to a newer CU. For example, if you are on Automation Suite 2024.10.0, the last supported version for your cluster is Kubernetes 1.30. When this version reaches its end of life, you must update your cluster to a newer Kubernetes version. This also requires updating to a newer Automation Suite CU.
                                  Automation Suite version  |
                                  Compatible Kubernetes versions  |
| 2024.10.5 | 1.31, 1.32 , 1.33 |
| 2024.10.4 | 1.30 , 1.31, 1.32 |
| 2024.10.3 |
                                  1.30 , 1.31, 1.32  |
| 2024.10.2 |
                                  1.29, 1.30 , 1.31  |
                                  2024.10.1  |
                                  1.28, 1.29 , 1.30  |
                                  2024.10.0  |
                                  1.28, 1.29 , 1.30  |
