- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Saving robot logs to an Elasticsearch server can be achieved through two types of configuration: basic and advanced.
The basic configuration provides default functionality that activates the preconfigured Elasticsearch NLog target, which is made up of an Elasticsearch target wrapped in a Buffering target. This type of configuration is enough in most scenarios.
However, if you need to further customize the rules, you can use the advanced configuration method.
To apply the basic configuration, take the following steps. For more details, see Configuring the Orchestrator parameters.
The basic configuration supports Elasticsearch version 7.x. For Elasticsearch 8.x, you need to use the advanced configuration.
NLog.config target.
- Follow the basic configuration steps described previously.
- Follow the Advanced NLog configuration steps, then update the
robotElasticBuffertarget with the properties that need to be changed.
The advanced configuration also supports Elasticsearch version 8.x.
nlog.config.json for Elasticsearch 7.x
"Nlog": {
"targets": {
"robotElasticBuffer": {
"flushTimeout": 1000,
"bufferSize": 1000,
"slidingTimeout": false,
"target": {
"uri": "https://elastic.example.com:9200",
"requireAuth": true,
"username": "elastic-user",
"password": "elastic-password",
"index": "${event-properties:item=indexName}-${date:format=yyyy.MM}",
"documentType": "logEvent",
"includeAllProperties": true,
"layout": "${message}",
"excludedProperties": "agentSessionId,tenantId,indexName"
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
}nlog.config.json for Elasticsearch 8.x
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
"documentType": "",
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
"documentType": "",
