- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Installation permissions are relevant only if you cannot provide admin privileges to the Automation Suite installer. If you can provide the required admin privileges to the installer, you do not need to follow the instructions in this section.
Automation Suite requires the Istio service mesh for ingress and networking.
The service mesh installation and configuration is a two-step process. Which of the steps you must perform depends on whether or not you can grant the Automation Suite installer admin privileges over your cluster. For details, see the following table:
Step |
Admin privileges |
No admin privileges |
| Step 1: Installing the service mesh |
Step not required |
Required step |
| Step 2: Configuring Istio and installing the WASM plugin for routing |
Step not required |
Required step |
To install Istio, follow the instructions in the Istio documentation.
Automation Suite does not require applications such as Kiali and Jaeger. However, you can use them at your discretion.
Providing the Istio configuration
input.json file:"ingress": {
"gateway_selector": {
"istio": "ingressgateway"
"ingress_gateway_secret": "istio-ingressgateway-certs",
"namespace": "<istio-system>"
},"ingress": {
Parameter |
Value |
ingress.gateway_selector.istio |
Default value:
ingressgatewayIf you have changed the value, then use the following command to get the right value: |
ingress.ingress_gateway_secret |
The name of the secret that contains the certificate files. The default value is
istio-ingressgateway-certs.
ingress.namespace | The namespace where you have installed the service mesh. |
This step requires admin privileges for installation in the Istio namespace.
Option A: If you cannot provide the permissions that the Automation Suite installer requires, then you must perform this step before the Automation Suite installation.
Option B: During the Automation Suite installation. This method requires the Kubeconfig file that you use during the Automation Suite installation to have the necessary permissions. To review the permissions, refer to the Granting installation permissions section. If you can provide all the necessary permissions, then skip this step.
Configuration and installation
To configure Istio and install the WASM plugin for routing, take the following steps:
When you install Automation Suite in a shared cluster, if you update the FQDN post-installation, one of the following scenarios applies:
If you grant the Automation Suite installer admin privileges and you did not add the
istio-configurecomponent to theexclude_componentslist in yourinput.jsonfile, you do not need to perform any additional step. -
If you do not grant the Automation Suite installer admin privileges and you added the
istio-configurecomponent to theexclude_componentslist in yourinput.jsonfile, you must take the following steps:-
Update the parameter values file mentioned in Point 3 with the new FQDN.
Repeat all the steps for configuring Istio and installing the WASM plugin for routing.
