- Overview
- Requirements
- Pre-installation
- Migration and upgrade
- Upgrading Automation Suite
- Migrating from Automation Suite on EKS/AKS to Automation Suite on OpenShift
- Monitoring and alerting
- Cluster administration
- Troubleshooting
- The backup setup does not work due to a failure to connect to Azure Government
- Pods in the uipath namespace stuck when enabling custom node taints
- Unable to launch Automation Hub and Apps with proxy setup
- Robot cannot connect to an Automation Suite Orchestrator instance
- Log streaming does not work in proxy setups
- Velero backup fails with FailedValidation error
- Accessing FQDN returns RBAC: access denied error
Automation Suite consists of multiple components. Both you as a customer and UiPath® share responsibility of these components. For details, see Responsibility matrix.
You are responsible for upgrading:
- Kubernetes infrastructure where Automation Suite is deployed (AKS or EKS)
- Components that you choose to bring as part of Automation Suite (e.g., Gatekeeper, FluentD, etc.)
UiPath® is responsible for upgrading:
- UiPath® services (e.g., Orchestrator)
- Components deployed as part of Automation Suite (e.g., ArgoCD)
Preparation
AutomationSuite_Airflow and configure the connection string for it in input.json.
Refer to Process Mining-specific configuration for details.
There is a known issue with the backup logic in Automation Suite for AKS/EKS versions 2024.10.0 to 2024.10.1. Specifically, this issue excludes the backup of Insights dashboards and Studio Web data. However, all historical data is successfully backed up.
Execution
To perform an upgrade of UiPath® services and component, take the following steps:
You are responsible for upgrading the Kubernetes infrastructure hosting Automation Suite. You should follow the standard practices of your company to upgrade Kubernetes infrastructure.
