2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- SQL validation fails during upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
Last updated Mar 17, 2025
When trying to upgrade to a new Automation Suite version,
validateUiPathASReadiness.sh can fail to validate SQL connectivity.
The
validateUiPathASReadiness.sh script uses the podman command to run containers to verify the SQL connection.
If there is any corruption in the Podman system data, the
podman command can fail to run and, consequently, can cause the validateUiPathASReadiness.sh execution to fail also.
You can verify if there is any Podman data corruption by running the
podman volume ls or podman secret ls command. If the previous commands fail, you can reset the Podman files by running the podman system reset command.
Note:
The
podman system reset command stops all Podman containers and removes all images, volumes, networks, and container content.
