- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
This page explains how you can perform an online Automation Suite installation with a multi-node HA-ready production setup.
You must meet the hardware and software prerequisites before proceeding with the installation. See Hardware and software requirements.
You can use a dedicated script to validate the installation prerequisites and infrastructure readiness. See Validating the prerequisites.
For a smooth installation experience, make sure to follow our best practices. See .
These steps will enable you to install the Automation Suite across multiple machines. Internet access is required for this mode of installation.
The installation process has the following general steps:
Step |
Description |
Step 1: Download the Installation Packages |
This step needs to be performed from a machine with access to internet where Automation Suite will be deployed. While these are finishing downloading you can continue onto some of the next steps. |
Step 2: Configure the Installation |
Step 2.1: Run the interactive install wizard to configure the installation options The tool will gather inputs for most common install options and generate a configuration file that will be used during the installation. Step 2.2: (Optional) Configure advanced installation options The default install configuration includes the products used in core automation and a shared SQL server to be used by all products. To customize the products installed or have separate SQL servers used for specific products you can do so by editing the configuration file. |
Step 3: Complete the installation |
Step 3: You have completed the installation successfully and can move to post-installation steps. You can now access the newly created cluster and suite, update certificates, resize the PVC, and more. |
RHEL kernel version kernel-4.18.0-477.10.1.el8_8 is affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses this kernel version either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libsdnf install -y kernel kernel-tools kernel-tools-libsYou must perform this step from a machine with internet access where Automation Suite will be deployed. While these are finishing downloading, you can continue with the next steps.
To copy the interactive installer to the target machine, take the following steps:
Run the installer on the first server only.
chmod +x ~/installUiPathAS.sh
./installUiPathAS.shchmod +x ~/installUiPathAS.sh
./installUiPathAS.shStep 2.1: Basic configuration
Run the interactive install wizard to configure the installation options. The tool gathers inputs for most common installation options and generates a configuration file that you can use during the installation.
If you run the installation using the default configuration, you opt for the default experience. You will install our core platform, Orchestrator, Insights, Action Center, Test Manager, Automation Ops, Automation Hub, and Data Service.
To install Automation Suite using the interactive installer, take the following steps:
Step 2.2: (Optional) Advanced configuration
This step is optional.
By running the installation using the default configuration, you are opting to run our basic product selection. You will install our core platform, Orchestrator, Insights, Action Center, Test Manager, Automation Ops, Automation Hub, and Data Service.
You can configure the file for more advanced configurations. You can enable additional products, disable any of the default products, configure your SQL DBs and their respective connection strings, and certificates. For multi-node HA-ready production mode, we enable High Availability by default, but you can disable it if needed.
For advanced configuration, you can follow the following instructions: Advanced installation experience.
Updating Certificates
The installation process generates self-signed certificates on your behalf. However, the Azure deployment template also gives you the option to provide a CA-issued server certificate at installation time instead of using an auto-generated self-signed certificate.
Self-signed certificates will expire in 90 days, and you must replace them with certificates signed by a trusted CA as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
For instructions, see Managing certificates.
Accessing Automation Suite
To access the newly created cluster and suite, see Accessing Automation Suite.
Resizing PVC
To resize the PVC, see Resizing PVC.
If you installed AI Center, we recommend resizing the PVC to 200 immediately after the installation to avoid downtimes. For more information on this, check Resizing PVC for AI Center.
