- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
If you are trying unsuccesfully to deploy a Document Understanding ML Skill on AI Center, check the solutions below.
If you are installing the Automation Suite offline, please double check if the Document Understanding bundle has been downloaded and installed.
The bundle includes the base image (e.g., model library) for the models to properly run on AI Center after uploading the ML Packages via AI Center UI.
modulenotfounderror: no module named 'ocr.release'; 'ocr' is not a package.
When creating a Document Understanding OCR ML Package in AI Center, keep in mind that it cannot be named ocr or OCR, which conflicts with a folder in the package. Please make sure to choose another name.
Failed to list deployment or Unknown Error when deploying the model for the first time.
The workaround is to try deploying the model again. The second time, the deployment is be faster as most of the deployment work of image building would have been done during the first attempt. Document Understanding ML Packages take around 1-1.5 hours for deploying the first time, and these are faster when deploying them again.
