2022.4
- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Document Understanding Not on the Left Rail of Automation Suite
- Failed Status When Creating a Data Labeling Session
- Failed Status When Trying to Deploy an ML Skill
- Migration Job Fails in ArgoCD
- Handwriting Recognition With Intelligent Form Extractor Not Working
- Exploring Logs
Last updated Mar 17, 2025
In case Document Understanding cannot be found on the left rail of Automation Suite, please know that Document Understanding is currently not a separate application on Automation Suite, thus it is not shown on the left rail.
The Data Manager component is part of AI Center, so please make sure to enable AI Center.
Also, please access Form Extractor, Intelligent Form Extractor (including HandwritingRecognition), and Intelligent Keyword Classifier, with the below public URL:
<FQDN>/du_/svc/formextractor
<FQDN>/du_/svc/intelligentforms
<FQDN>/du_/svc/intelligentkeywords
If you get the
Your license can not be validated error message when trying to use Intelligent Keyword Classifier, Form Extractor and Intelligent Form Extractor in Studio,
besides making sure you have input the right endpoint, please also take the API key that you generated for Document Understanding
under License in the Automation Suite install, and not from cloud.uipath.com.
