- Overview
- Requirements
- Cluster administration
- Managing products
- Managing the cluster in ArgoCD
- Setting up the external NFS server
- Automated: Enabling the Backup on the Cluster
- Automated: Disabling the Backup on the Cluster
- Automated, Online: Restoring the Cluster
- Automated, Offline: Restoring the Cluster
- Manual: Enabling the Backup on the Cluster
- Manual: Disabling the Backup on the Cluster
- Manual, Online: Restoring the Cluster
- Manual, Offline: Restoring the Cluster
- Additional configuration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- B) Single tenant migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- RKE2 fails during installation and upgrade
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis Probe Failure
- RKE2 Server Fails to Start
- After the Initial Install, ArgoCD App Went Into Progressing State
- RabbitMQ pod stuck in CrashLoopBackOff
- Exploring Logs
- Make sure you meet the Prerequisites.
- Make sure the backup is disabled on the backup cluster. Inconsistencies will occurs if a new backup is created while cluster restore is in progress. See Disabling the backup on the cluster.
- Make sure package wget, unzip, jq are available on all the restore nodes.
- All external data sources must be the same (SQL Server).
- Restart the NFS server before restoring the cluster by running the following command on the NFS server node:
systemctl restart nfs-server. -
The restore cluster should have the same FQDN as the backup cluster.
Installation type
Configuration instructions
Requirements
Offline single-node evaluation mode
Download the following files:
sf-installer.zip– Mandatory. See sf-installer.zip for download instructions.sf-infra.tar.gz– Mandatory. See sf-infra.tar.gz for download instructions.
Offline multi-node HA-ready production mode
Download below files
To restore etcd on the first node of the cluster, run:
./install-uipath.sh -i restore.json -o output.json -r --offline-bundle "../sf-infra.tar.gz" --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreement --install-type offline
To restore etcd on the other server nodes of the cluster, run:
./install-uipath.sh -i ../restore.json -o output.json -r -j server --offline-bundle "../sf-infra.tar.gz" --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreement --install-type offline
To restore etcd on agent nodes of the cluster, run:
./install-uipath.sh -i restore.json -o output.json -r -j agent --offline-bundle "../sf-infra.tar.gz" --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreement --install-type offline
To restore etcd on Task Mining agent nodes of the cluster, run:
./install-uipath.sh -i restore.json -o output.json -r -j task-mining --offline-bundle "../sf-infra.tar.gz" --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreement --install-type offline
To restore etcd on GPU agent nodes of the cluster, run:
./install-uipath.sh -i restore.json -o output.json -r -j gpu --offline-bundle "../sf-infra.tar.gz" --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreement --install-type offline
Before restoring the volume, you need to disable the maintenance mode:
./configureUiPathAS.sh disable-maintenance-mode./configureUiPathAS.sh disable-maintenance-modeOnce the etcd restore is complete, restore the volume on any of the server node by running:
\./install-uipath.sh -i restore.json -o output.json -r --volume-restore --accept-license-agreement --install-type offline
After restoring an Automation Suite cluster with AI Center™ enabled, follow the steps from the Enabling AI Center on the Restored Cluster procedure.
cluster_config.json for future. You may need it when adding new nodes to the cluster, when upgrading, etc.
cluster_config.json, run the following command from any of the server nodes:
./configureUiPathAS.sh config get -o ./cluster_config.json
After restoring the cluster, make sure to add your CA certificates to the trust store of the restored VMs. For details, see:
- Before You Begin
- Preparing the Restore Operation
- Restoring Etcd on the First Server Node
- Restoring Etcd on the Remaining Server Nodes
- Restoring Etcd on Agent Nodes
- Restoring Etcd on Task Mining Nodes
- Restoring Etcd on GPU Nodes
- Disabling the Maintenance Mode
- Running Volume Restore on Any Server Node
- Enabling AI Center on the Restored Cluster
- Restoring Cluster_config.json
- Adding CA certificates to the trust store
