Process Mining
Last updated Jan 15, 2026
Adding input tables
You can easily add input tables by uploading CSV files in the Data transformations editor. Adding an input table in the Data transformations editor does not trigger a new data run. This enables you to create the required SQL queries step-by-step when adding new input tables.
Follow these steps to add one or more input tables to the Input data.
  1. Select the Add file(s) icon Add files icon in the Input data section of the Data transformations editor.
  2. Drag and drop one or more files that contain the data for the process app, or use the Select files option, to select the files from your computer.
  3. Check the detected details for your dataset in the Encoding and Delimiter list boxes. If needed, select the appropriate settings.
  4. Select Upload.
The files are uploaded and the new tables are added to the Tables list in the Input data section.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
