Process Mining user guide
Last updated Apr 23, 2026
Adding input tables
You can easily add input tables by uploading CSV files in the Data transformations editor. Adding an input table in the Data transformations editor does not trigger a new data run. This enables you to create the required SQL queries step-by-step when adding new input tables.
Note:
Always make sure that the input data is in the required format for the app template used for the process app. Refer to App templates.
Follow these steps to add one or more input tables to the Input data.
  1. Select the Add file(s) icon Add files icon in the Input data section of the Data transformations editor. The Tables page is displayed.
  2. Select the file or files that contain the data for the process app from your computer.
  3. Select Open. The files are uploaded and a new table is automatically added in the Source tables section for each uploaded file and a corresponding input table is created in the Target tables section.
  4. Make sure each source file is mapped to the correct target table.
  5. Select Next. The Fields page is displayed.
  6. For each table, make sure that the Source fields are mapped to the correct Target fields.
  7. Select Confirm. The Fields page is closed and the new table or tables are listed in the tables section.
Check out Managing input data for more information on mapping tables and fields.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
