- Before you begin
- Managing access
- Getting started
- Integrations
- Working with process apps
- Working with dashboards and charts
- Working with process graphs
- Working with Discover process models and Import BPMN models
- Showing or hiding the menu
- Context information
- Export
- Filters
- Sending automation ideas to UiPath® Automation Hub
- Tags
- Due dates
- Compare
- Conformance checking
- Root cause analysis
- Simulating automation potential
- Viewing Process data
- Creating apps
- Loading data
- Transforming data
- Tips for writing SQL
- Exporting and importing transformations
- Viewing the data run logs
- Merging event logs
- Configuring Tags
- Configuring Due dates
- Configuring fields for Automation potential
- Activity Configuration: Defining activity order
- Making the transformations available in dashboards
- Data models
- Adding and editing processes
- Customizing dashboards
- Publishing Dashboards
- App templates
- Notifications
- Additional resources
Process Mining user guide
Loading data using Theobald Xtract Universal
This page describes how to use Theobald Xtract Universal (XU) to load data from your SAP source system into a process app. Refer to the official Theobald Software website for more information on Theobald Xtract Universal (XU).
Theobald Xtract Universal provides fast data access and extractions to SAP ECC and SAP HANA data sources. For general instructions on how to use Theobald Xtract Universal, check out the official Theobald Software website Getting Started with Theobald Xtract Universal.
Prerequisites
It is assumed that you have:
- a valid Theobald Xtract Universal license.
Note:
The license is provided via UiPath® for the purpose of Process Mining.
- set up SQL Server access with the correct permissions. Check out Setting up a SQL Server account for data upload using an extractor.
Note:
Loading data using Theobald Xtract Universal requires that the command line tool (
xu.exe) can be executed without additional authentication.
Steps
Setting up data load using Theobald Xtract Universal requires several steps to be performed.
