Process Mining
Last updated Jan 15, 2026
Enabling Process Mining
Enabling Process Mining in Automation Suite
Process Mining is provided as part of the Automation Suite complete profile, hence it is enabled automatically. To disable Process Mining, follow the Advanced installation experience guide.
Access to Automation Suite
To start using the Process Mining service you need an Automation Suite account. Check out About accounts for more details.
License (Flex Plan)
Prerequisites for enabling the Process Mining service
You can enable Process Mining as a service, in Automation Suite, if you meet the following two pre-requisites:
  • You have an Enterprise Automation Suite license.
  • Your Automation Suite organisation has available AI Units (i.e. >0).
Note:
  • If you do not currently have an Enterprise licence, contact your Account Manager for available Enterprise Trials.
  • If you have an Enterprise license, but no AI Units available, contact your Account Manager to purchase some.
Flex plan
To enable the Process Mining service in Automation Suite, you must have at least:
  • 1 Developer user license.
  • 5 Business user licenses.
  • You need to have purchased at least 120K AI Units (two small AI Unit bundles).
Important:
Make sure the license period is still active.
Tenants and services
The Process Mining service that allows you to manage and set up process apps must be enabled on each of the tenants where the Process Mining service will be used.
Note: Process Mining is a tenant-level service signifying that each tenant's data is segregated. This means that you need to enable the service for each of the tenants where this is needed.
Changing localization settings
The default language is English. The language can either be changed globally, with the change being propagated to all the users accessing your organization, or at a local level, for yourself only.
Note: Process Mining App templates are not localized.
Check out Changing localization settings for more information.
Enabling the Process Mining service
To start using Process Mining in Automation Suite, you must enable the Process Mining service on a selected tenant. Follow these steps to enable the Process Mining services on a tenant.
  1. Log in to Automation Suite in with your UiPath® account.
  2. Select Admin to display the list of available tenants and enable the service for an already existing tenant.
  3. Locate the tenant for which you want to enable the Process Mining service.
  4. Select the Services tile.
    The Services page for the tenant opens, showing the services that are currently provisioned.
  5. Select Add services.
    Note: The button is only available if you have not already provisioned all services.
  6. Select the Process Mining checkbox in the Add services panel.
  7. Select Add.
The Add services panel closes and the tenant is briefly unavailable while the Process Mining service is being provisioned. When finished, the Process Mining service is displayed on the Services page.
When accessing the newly created/updated tenant, the Process Mining service is displayed on the left-hand side panel.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
