  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
  • Automation Suite on EKS/AKS Release Notes
  • Automation Suite on OpenShift release notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
    • 2024.10.6
Automation Suite release notes
Last updated Nov 6, 2025
2024.10.4
Release date: June 26, 2025
Disaster Recovery – Active/Passive deployments
We are happy to announce that Disaster Recovery in Active/Passive configuration is now supported for Automation Suite on OpenShift.
Now you can configure Automation Suite in a way that can withstand the complete failure of nodes, entire data centers, or even regions.
Automation Suite deployments in Active/Passive mode support the following scenarios:
  • Same-region deployment
  • Cross-region deployment
Changes to the patching procedure
The procedure for applying patches now includes an additional step that requires you to download and use the corresponding uipathctl patch version before proceeding with the patch.
For more details, refer to Applying a patch.
Changes to OpenShift version support
We have expanded our compatibility to include OpenShift version 4.17. Additionally, we have removed OpenShift version 4.13 from the list of compatible versions.
If you move from an older Automation Suite version, make sure you use a supported OpenShift version before starting the upgrade.
For more details about the supported OpenShift versions, refer to Compatibility matrix.
Bug fixes
  • Log forwarding did not work in proxy setups because the proxy environment variables were not set in the logging pods. We have fixed the issue.
  • Licensing SQL connection errors occurred when the Data Source property specified both a named instance and a port. We have fixed the issue.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
AI Center 2024.10.4Action Center 2024.10.4
AI Computer Vision 2024.10.4Insights 2024.10.5Apps 2024.10.4
  Orchestrator 2024.10.6
  Test Manager 2024.10.4
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
