  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
  • Automation Suite on EKS/AKS Release Notes
    • 2024.10.4
  • Automation Suite on OpenShift release notes
Automation Suite release notes
Last updated Jun 26, 2025
2024.10.1
Release date: April 28, 2025
Support for full migration
Full migration is now supported in Automation Suite 2024.10.1.
Compared to the full migration steps in Automation Suite 2023.10, in this version there is an additional migration step in which you can update the schema of the Insights and Orchestrator databases after previously restoring them.
Also, we implemented the following improvements in the UiPath.OrganizationMigrationApp tool:
  • We provide an inner exception during a database connection test for enhanced error logging and debugging.
  • We improved the merging process of single sign-on users (SSO) from multiple organizations to handle database conflicts more efficiently. The update also provides accurate migration success messages and prevents potential data duplication. This enhancement significantly benefits organizations utilizing the MSI to Automation Suite setup with a multi-tenant configuration and SSO.
For more details, refer to Performing a full migration.
Release date: December 18, 2024
Important:
Erratum - added January 23, 2025: We have identified an issue with Integration Service on Automation Suite 2024.10.1, which can cause increased infrastructure load, if misconfigured. As a result, we have removed Integration Service from the mentioned versions. Integration Service will be available again in Automation Suite 2024.10.2.
If you already use Integration Service on Automation Suite 2024.10.1, reach out to the UiPath Product Support for more details.
Improvements
  • Studio Web is now supported on machines with Federal Information Processing Standards 140-2 (FIPS 140-2) enabled.
  • Studio Web now supports workload identity.
  • Integration Service and Studio Web now support offline environments.
Bug fixes
  • We have fixed an Automation Suite installation issue that occurred when using an SQL Server version prior to 2019.
  • We have fixed an issue that caused Insights volumes to be created in two different zones following migration from Automation Suite on Linux to Automation Suite on EKS/AKS.
  • We have fixed an issue causing Automation Hub to become inaccessible after an upgrade to Automation Suite 2024.10.
  • When using style attributes in the HTML tags while customizing your Login page, they reflected accurately in the preview. However, upon saving the changes, the style attributes were deleted automatically. Now, all style attributes used within tags persist after saving your changes.
  • We have fixed an issue causing the upgrade to fail due to the overriding of existing Insights PVC sizes.
  • We fixed a bug that was breaking SAML2 when basic authentication was disabled, along with various other bugs.
  • You can now forward logs to external tools, such as Splunk, using the OpenTelemetry Collector if you have opted for the Prometheus Grafana stack. Previously, this function was unavailable due to the switch to kube-logging.
Known issues
Log streaming does not work in proxy setups
Erratum - added June 26, 2025: Log forwarding does not work in proxy setups because the proxy environment variables were not set in the logging pods. To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2024.10.4.
Deployment issue on shared EKS clusters with custom namespace
Erratum - added June 26, 2025: An issue causes the Automation Suite deployment on a shared EKS cluster to fail if the target namespace is not uipath. This issue is due to the network policy incorrectly expecting the presence of a uipath namespace regardless of the chosen namespace.
To address the issue, you must manually create a uipath namespace before deploying Automation Suite.
We have fixed this issue in Automation Suite 2024.10.4.
Kubernetes upgrade failure
Erratum - added June 26, 2025: An issue causes the Kubernetes upgrade to fail due to an incorrect configuration in Integration Service. The upgrade failure triggers the following error message: Cannot evict pod as it would violate the Pod’s disruption budget.
To address the issue, you must increase the replica count of intsvcs-periodicdeployment using the following command:
kubectl scale deployment intsvcs-periodic --replicas=2 -n  uipathkubectl scale deployment intsvcs-periodic --replicas=2 -n  uipath
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Service disruptions due to automatic secret rotation
Erratum - added May 14, 2025: An issue causes service disruptions due to the automatic secret rotation, making services temporarily inaccessible.
To address this issue, take the following steps:
  1. Restart the affected service to restore its normal functionality.
  2. Navigate to the ArgoCD UI and from the platform applicatio, select Details > Parameters. Edit the values to add "secretRotation: enabled: false" under identity-service. You must take this step after each Automation Suite upgrade or reinstallation.
For AI Center, all skills must be stopped and started from AI Center UI.
OAuth token refresh issue due to incorrect version
Erratum - added April 28, 2025: Due to an incorrect version of intsvcs/oauth-token-refresh configured at the service level, the OAuth token refresh job is attempting to fetch a version that is not available in the UiPath offline registry. This causes issues during execution.
We have fixed this issue in Automation Suite 2024.10.3.
Insights dashboards and Studio Web data excluded from backups
Erratum - added April 2, 2025: An issue is preventing the inclusion of Insights dashboards and Studio Web data in backups. To address this issue, refer to the Backing up the cluster page. The issue is fixed in Automation Suite 2024.10.2.
Orchestrator and AI Center require SQL Sever version 2019 and higher
Erratum - added February 27, 2025: For this version of Automation Suite, you need to use SQL Server version 2019 or higher for proper operation of Orchestrator and AI Center.
Fluentd logs transmission failure
Erratum - added February 17, 2025: An issue prevents Fluentd from sending logs to remote locations due to a lack of memory buffer. To address this issue, you must add a memory limit for Fluentd to prevent disruptions or delays when transmitting logs to a remote location.
This issue is fixed in Automation Suite 2024.10.2.
Microsoft Entra ID limitations
Erratum - added January 20, 2025: Insights, Studio Web, and Task Mining do not currently support Microsoft Entra ID (formerly Azure Active Directory) authentication configuration for access to SQL, storage, and other resources that support Microsoft Entra.
Full migration from standalone products to Automation Suite not supported
You cannot currently perform a full migration from standalone products version 2024.10 to Automation Suite 2024.10 using the UiPath.OrganizationMigrationApp tool. We are actively working on introducing support for this scenario.
In the meantime, you can perform a single-tenant migration. For details on this migration option, refer to Single tenant migration.
Insights dashboards backup issue
We have identified an issue with the backup logic in Automation Suite for AKS/EKS. Specifically, this defect excludes the backup of Insights dashboards. However, all historical data is successfully backed up.
We are working diligently to resolve this issue. We aim to develop and implement a mitigation approach as early as possible.
If you are using Automation Suite on AKS/EKS along with UiPath Insights, this defect may affect your operations. While we address this issue, we suggest manually exporting your dashboards as a preventive measure.
Note that backups are mainly used as a recovery method in the event of a disaster-level incident or in preparation for an Automation Suite upgrade. This is particularly useful if an upgrade fails and stored data needs to be restored to its previous state.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
AI Center 2024.10.1Action Center 2024.10.1
Task Mining 2024.10.1AI Computer Vision 2024.10.1Insights 2024.10.1Apps 2024.10.1
Orchestrator 2024.10.2
  Test Manager 2024.10.1
Internal third-party component versions
This Automation Suite release bundles the following internal components:
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
Component
Version
Istio
1.23.0
ArgoCD
2.12.6
Prometheus
2.55.1
Grafana
11.3.0
Fluentd and Fluent-bit
logging-operator: 4.10.0
logging-operator-logging: 4.10.0
Gatekeeper
3.17.1
Cert-Manager
1.16.1
Velero
7.2.2
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
