  • Automation Suite on Linux Release Notes
    • 2024.10.0
    • 2024.10.1
    • 2024.10.4
    • 2024.10.5
  • Automation Suite on EKS/AKS Release Notes
    • 2024.10.5
  • Automation Suite on OpenShift release notes
Automation Suite release notes
Last updated Oct 8, 2025
2024.10.4
Release date: June 26, 2025
Changes to the patching procedure
The procedure for applying patches now includes an additional step that requires you to download and use the corresponding uipathctl patch version before proceeding with the patch.
For more details, refer to Applying a patch.
Deprecation of UiPath managed backup
Starting with Automation Suite 2025.10, if you are using Automation Suite on AWS EKS or Azure AKS, you will need to leverage the AWS or Azure managed backup solution for backups. This allows you to unify your cloud backup strategy. The backup solution previously managed by UiPath will no longer be available.
Bug fixes
  • We have fixed an issue causing the Automation Suite deployment on a shared EKS cluster to fail when using a namespace different from uipath. The network policy helm chart now correctly handles custom namespaces.
  • An issue was causing the Kubernetes upgrade to fail due to an incorrect configuration in Integration Service. The upgrade failure triggered the following error message: Cannot evict pod as it would violate the Pod’s disruption budget. We have fixed the issue.
  • Log forwarding did not work in proxy setups because the proxy environment variables were not set in the logging pods. We have fixed the issue.
  • Licensing SQL connection errors occurred when the Data Source property specified both a named instance and a port. We have fixed the issue.
Known issues
Velero backup fails with FailedValidation error
Erratum - added September 24, 2025: An issue prevents Velero scheduled backups from running successfully. A FailedValidation error message is displayed, indicating that no default backup location can be found. This issue occurs because the default-bs1 backup storage location is not marked as the default. As a result, Velero cannot identify a valid backup target, and scheduled backups fail.
To address the issue, refer to the Troubleshooting section.
We fixed the issue in Automation Suite 2024.10.5.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
AI Center 2024.10.4Action Center 2024.10.4
Task Mining 2024.10.4AI Computer Vision 2024.10.4Insights 2024.10.5Apps 2024.10.4
Orchestrator 2024.10.6
  Test Manager 2024.10.4
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
Component
Version
Istio
1.25.2
ArgoCD
3.0.0
Prometheus
3.3.0
Grafana
11.6.1
Fluentd and Fluent-bit
logging-operator: 5.3.0
fluent/fluent-bit:4.0.1
Gatekeeper
3.19.1
Cert-Manager
1.17.2
Velero
9.1.0
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
